ZUKIWORLD Discussion Forum => Suzuki 4x4 Forum => Topic started by: bentparts on December 28, 2005, 02:43:44 PM
Title: drivers side front axle removal
Post by: bentparts on December 28, 2005, 02:43:44 PM
 ??? I've got my front diff housing on thae bench and want to remove the drivers side axle, in order to remove the carrier. Before I attach a slide hammer to the flange to pull it out, is there somthing I should know? Like  is there a circlip or some other fastener inside the housing or is it like the ear axle and just a pressed in bearing?   I did a search on this and could only find info on the pass side. Thanks
Title: Re: drivers side front axle removal
Post by: bentparts on December 28, 2005, 03:51:33 PM
 :D Got It! A little more searching, and a BFH. I still can't get used to all this hammering and pounding, I've been workin' on Harleys too long.
Post by: darnold87 on December 28, 2005, 05:25:08 PM
It just came out using more force, correct?  ...shouldn't be anything keeping it in there like a c-clip?
Post by: bentparts on December 28, 2005, 05:43:57 PM
 It had the same c-clip. wire type , as the other side. Couple of whacks, and it came right out.
