ZUKIWORLD Discussion Forum => Suzuki 4x4 Forum => Topic started by: ebewley on January 28, 2017, 09:02:30 AM
TECH LIBRARY – FREE DOWNLOADS
RESEARCH – Downloadable documents for your Suzuki
FSM (Factory Service Manuals), USR (User Created Documents), OWN (Owner’s Manual), TSB (Technical Service Bulletin), Sales Brochures, etc.. Files from all over the ‘net with credit given when known. Please contact us if you have a file you’d like to add that may help the Suzuki automotive community.
http://www2.zukiworld.com/tech-library-documentation-downloads-for-your-suzuki/ (http://www2.zukiworld.com/tech-library-documentation-downloads-for-your-suzuki/)
Continually growing list!
FSM - Samurai Fuel Injection Supplement Manual rhinoman 99501-83350-33E.pdf 158.2 MB
FSM - Samurai Maintenance Manual 99500-83300-33E.pdf 266.4 MB
FSM - Sidekick 1996 Air Conditioning.pdf 1.9 MB
FSM - Sidekick Vitara Service Manual rhinoman 99500-60A10-01E.pdf 27.7 MB
FSM - Swift Electrical Component Locator 1.3L TBI.pdf 68.1 KB
FSM - Swift GT ECM Electrical.pdf 171.5 KB
FSM - Swift GT G13B Cam Timing.pdf 63.6 KB
FSM - Swift GT G13B TPS Adjustment.pdf 120.9 KB
FSM - Swift GT ISC Solenoid Valve.pdf 85.4 KB
FSM - Swift GT Ignition System.pdf 20.9 KB
FSM - Swift GT Junction Fuse Block.pdf 81.2 KB
FSM - Swift GT Manual Transmission Schematic.pdf 221.5 KB
FSM - Swift Supplimental Four-Wheel Drive 99501-71C00-01E.pdf 15.5 MB
FSM - Vitara 1999-2005 Chassis Electrical Body Manual .pdf 20.2 MB
FSM - Vitara 1999-2005 Engine Drivetrain Manual.pdf 8.0 MB
FSM - Vitara 1999-2005 Full Service Manual.pdf 12.1 MB
FSM - Vitara 1999-2005 Service Manual Canvas Top Supplemental.pdf 1.9 MB
FSM - Vitara 1999-2005 Transmission Transfer Case Differential Manual .pdf 6.0 MB
OWN - Tracker Owners Manual 1998.pdf 20.4 MB
TSB - AC Compresor Refrigerant Oil Checking.pdf 48.1 KB
TSB - AC Compresor Servicing.pdf 68.9 KB
TSB - AC Compresor and Magnetic Clutch Assembly.pdf 505.7 KB
TSB - AC System General Servicing.pdf 85.4 KB
TSB - AC System Specifications.pdf 46.0 KB
TSB - AT Transmission Controler Change Bulletin.pdf 69.6 KB
TSB - Alternators and Regulators.pdf 116.6 KB
TSB - Battery Maintenance.pdf 71.1 KB
TSB - Brake System.pdf 114.2 KB
TSB - Clutch and Compresor Asembly.pdf 69.0 KB
TSB - Drive Axles.pdf 99.0 KB
TSB - Engine 1.6L Diagnostics.pdf 258.1 KB
TSB - Engine Cooling.pdf 82.3 KB
TSB - Fuses and Circuit Breakers.pdf 55.2 KB
TSB - High Tension Wire Bulletin.pdf 58.3 KB
TSB - Hood Fly-Up Bulletin.pdf 121.9 KB
TSB - Idle Adjust.pdf 158.8 KB
TSB - Idle Speed-Isc Duty Adjustement.pdf 63.4 KB
TSB - Instrument Panel.pdf 108.0 KB
TSB - Modification Of The ECM Module.pdf 65.8 KB
TSB - Starter.pdf 152.8 KB
TSB - Swift G13B Engine Adjustments.pdf 158.8 KB
TSB - Swift GT General Specs 1 of 2.pdf 62.9 KB
TSB - Swift GT General Specs 2 of 2.pdf 158.8 KB
TSB - Swift GT Wiring Diagrams.pdf 600.4 KB
TSB - Swift MK3 Instrument Panel Testing.pdf 108.0 KB
TSB - Swift Wiring Diagrams.pdf 600.4 KB
USR - Samurai Usefull Random Parts Catalog.pdf 887.3 KB
USR - Sidekick Wiring Diagram and Instructions for 92-95 16v.pdf 3.5 MB
USR - Sidekick Wiring Diagram for 91-95 TBI.pdf 80.4 KB
USR - Sidekick Wiring Diagram for 92-95 16v OBD1.pdf 88.6 KB
USR - Sidekick Wiring Diagram for 96-98 16v OBD2.pdf 97.2 KB
USR - Swift GT Gauge Cluster Wiring.JPG 84.7 KB
Nothing in the tech library?
Whoops! That looks broken...
I'll work on fixing that. In the meantime, go to our daughter site izook.com there are downloads there.
Still don't see the files for downloading... Any updates on the "fix"?
OK, we've finally made some traction on this... It is a work in progress but there are now files available to download in our 'Tech Library'. We will be adding more and updating descriptions and so on as time permits.
Thanks, Eric
