Lifted the Whacker. Probs.
  • 68 Replies
  • 14397 Views
0 Members and 14 Guests are viewing this topic.
Offline Digger
  • 1991
  • 1996 Suzuki X-90 4X4
Re: Lifted the Whacker. Probs.
« Reply #15 on: January 16, 2006, 02:54:42 PM »
Why, is yours sitting nose-high? Shoot me an email so I might be able to help you out. SnakebiteEMS|removethispart|@hotmail.com
Offline Maroon Monsoon
  • 876
« Reply #16 on: January 16, 2006, 03:27:15 PM »
what do you make your coil spacers out of and how do you do it? with the 1.2" spacers do you need to flip the strut mounts? and how do you do so?   I have a 2000 grand vitara.. would work with the same spacers a kick would for sure though.
Offline da_tub
  • 307
« Reply #17 on: January 16, 2006, 03:47:33 PM »
i think diggers kit is for the earlier models threw to 98,, i think un less he building the new style now... not sure... but his way is a good cheap way  8)  i know i'm happy with it ;D
91 four door ,and some stuff
Offline Digger
  • 1991
« Reply #18 on: January 16, 2006, 04:51:22 PM »
I make them out of UHMW Polyetheylene. The same material used in "Professional" spacers. If you search around here, you'll find a topic I created on how to make your own spacers. It's very informative reading;) LOL! I have never tested my spacers on a newer style tracker, so I don't want to tell you for sure that they would work fine. Check out the garage sale forum, there's another person selling a complete lift kit for the newer style trackers and he put considerable time and effort into making a nice complete kit.
Offline Digger
  • 1991
« Reply #19 on: January 16, 2006, 04:55:02 PM »
Here's the other kit I told you about:
http://www.zukiworld.com/forum/index.php?topic=8494.0
  • 876
« Reply #20 on: January 16, 2006, 05:33:15 PM »
Thanks man, I'll look for that other topic. I am positive the spacers for a kick would work for my GV though because Rocky road's spacers fit GV's XL7's, sidekicks and trackers... thanks for the link for that guy's lift kit
Offline toolman21
  • 229
« Reply #21 on: January 16, 2006, 07:39:52 PM »
There was a company on ebay that offered the strut spacers with a spring spacers kit for sidekicks/trackers.  I contacted them to see if they would sell just the spacers and they said yes, and I "think" they were $35.  But it is my understanding the mount flip should be what you need.  Although my struts are stuck in the rubber mount and I can't flip mine....:-(
Toolman
  • 876
« Reply #22 on: January 16, 2006, 09:18:48 PM »
what do you have? I was looking at mine and I can't figure out how the strut bar would still work it the mounts were flipped
« Reply #23 on: January 16, 2006, 10:01:37 PM »
Nate and Heather again.
It's the only How-Tos I have earmarked.
http://www.zuwharrie.com/content/view/11/27/1/1/
Strut mount flip. ;D
« Reply #24 on: January 17, 2006, 04:52:15 AM »
I seem to recall someone saying that the GV strut top mounts were different.
Offline Uncivilized
  • 1469
    • Car Domain
« Reply #25 on: January 17, 2006, 05:45:14 AM »
I think they have a strut tower bar too for added strength and support, that might be the problem, or causing confusion??
Offline the_maplebar
  • 466
« Reply #26 on: January 17, 2006, 08:46:00 AM »
The GV mounts are different.  First they are bigger and taller, if you could flip them you would get  at least 4-6" of extra down travel, way too much.  Also if you flip them you would not be able to use the the strut brace.  Flipping the strut mounts on the GV's is not an option.
You will need to either buy longer struts (OME) or use strut spacers.  If you use strut spacers you will have to do something to relocate the brace (raise it up higher since to the mount was lowered).  Here are some pics of the sidekick strut mount next to the GV strut mount that I grabbed from Jagular7's Webshots (which are no longer available)
Offline joe_and_jeep
  • Why have a Rev Limiter and not use it?
« Reply #27 on: January 17, 2006, 09:08:28 AM »
I flipped mine, punched out the studs and put the studs back thru upside down and reinstalled from the bottom. The pic is looking up from the wheelwell.
So whats that considered a strut mount?  An new pair of struts come with it?
I cut the spacer down, now I am at 1" 7/16 plus the isolater.  That right now?  And where do I get the camber correction kit?  How do you adjust camber on these?
« Last Edit: January 17, 2006, 09:12:17 AM by joe_and_jeep »
96 Tracker DD - 2in, 30s
95 Tracker Under the Knife - 4.3V6 - Rest Unknown
91 Jeep YJ Full Cage, Tri Link, D44/D44 35s
84 Jeep XJ Doubler HP44/9IN 35s
Offline Digger
  • 1991
« Reply #28 on: January 17, 2006, 09:27:01 AM »
There is no provision on a stock track/kick to correct camber. You have to get creative. If you have wider wheels, sometimes the extra leverage they create will help put camber back in spec. Other things you can do is get a camber bolt set or even grind out the upper hole on the lower mount to spindle to get some adjustment, use big washers and tighten the bolt, then once it's in the right spot, tack weld the washers to the strut so they can't slide...
« Reply #29 on: January 17, 2006, 09:37:11 AM »
I loosend the lower mount hoping it would be adjustable like so many millions of cars with struts but nope.  I was thinking about going to Lows and getting a Grade 8 bolt and notching it a little bit on the shank to allow some adjustment.  Anyone try that or is that what the $16 bolt is?
I think I will probably tear the damn thing apart for the third time and slot the strut on the lower mount.
