Lowering s sidekick
  • 26 Replies
  • 7462 Views
Offline Somer
  • 143
  • Hey, is it suppose to do that!!
    • D2
Re: Lowering s sidekick
« Reply #15 on: February 17, 2005, 11:41:17 AM »
what did you do for the ball joints? Because the ball joints on the sport are fixed to the lower arm
I used a set of ball joints from a 1.6L.  They fit too..
Offline droppedtracker
  • 238
  • its a tracker thing, you wouldnt understand!!!
« Reply #16 on: February 18, 2005, 04:40:31 AM »
How did you get it to align correctly after you just put the springs in? The air ride sounds good but then on thats almost half the cost of my car, with tires i would have the same amount in my car as supension and tires. I like the way you car sits that is perfect. How is the ride now?
well after i put the springs in i took it to a local shop and had it aligned. the ride now compared to stock is like night and day much better handles like a small sports car
Offline Bobzooki
  • 1754
  • Web Wheeler
« Reply #17 on: February 18, 2005, 05:16:30 AM »
Now you're getting the idea!
Cost of my Kick:  Just under $3,000
Cost of my mods:  Over $10,000
Still WAY less than I would have paid for a J**p with similar capabilities!
Bob
Tahoe 24' Fish-N-Fun Tritoon
115 HP Mercury outboard
« Reply #18 on: February 18, 2005, 04:21:30 PM »
I guess I got off a little cheaper ;)
Drop it
or
Jack it Up
Any Zuki is fine in my book ;D
But I prefer them up.
easier on the speed bumps ;D
« Last Edit: February 18, 2005, 04:21:52 PM by trickker »
Offline mineisbroke
  • 134
  • yip
« Reply #19 on: February 19, 2005, 11:14:37 AM »
don't heat the springs . if you want a cheap way out just remove the springs and cut off desired amount and then reinstall them .don't forget that 2 inches of spring will lower the vehicle almost twice that amount . the control arms will be more horizontal to the ground making more leverage on the suspension for a softer ride than stock even though the spring rate has been altered . take it to the alignment shop and you shouldn't have any problems .  ;)
Offline RIKSTR
« Reply #20 on: February 19, 2005, 06:01:46 PM »
I just cut the springs for my parts chaser! ;D ;D ;D
Offline Suzuki1.8
  • 283
  • Tires so low looks like i'm riding on blades
« Reply #21 on: February 20, 2005, 08:22:22 AM »
I found a lowering kit from skunk2 that will just replace springs and then i'll  take it to a alignment shop and get it aligned. thank you for all the helpful advice
Offline Somer
  • 143
    • D2
« Reply #22 on: February 20, 2005, 07:28:04 PM »
What will you do about the camber?  The alignment shop can fix the toe in and out, but there is no way to adjust the camber, or is it less of a concern when dropping a Kick?
Offline Cwkick
  • 888
« Reply #23 on: February 20, 2005, 08:24:04 PM »
Camber bolts will help eliminate any camber issues.
Cwkick
« Last Edit: February 20, 2005, 08:24:19 PM by Cwkick »
Offline Suzuki1.8
  • 283
« Reply #24 on: February 21, 2005, 02:18:53 AM »
Cwkick
Yeah i spoke with les schawb and they said camber bolts since it not i huge change in geomerty of the suspension. The  front axle housing stays in the same place and it doesn't put any werid angle on the cv shafts. basicly like i think someone mentioned before the springs will only be 1 inch shorter then stock but will give a 2inch drop when compressed.
Offline Suzuki1.8
  • 283
« Reply #25 on: February 21, 2005, 06:52:18 AM »
so i got bored and made a image i'm going to have made into some stickers what you think?
Offline RIKSTR
« Reply #26 on: February 22, 2005, 07:11:45 PM »
Looks good and the camber pins are the ticket. I put them in mine and it fixed the camber nicely ;D
