A Chance at another GEO TRACKER! Help me out!
  • 17 Replies
  • 5380 Views
Offline Carnage
  • 2453
Re: A Chance at another GEO TRACKER! Help me out!
« Reply #15 on: April 05, 2006, 02:18:17 PM »
well the next one i have on the chopping block is getting the buttom end built to hold boost, and the heads will get oversized valves and its getting a t4 turbo, one should thing building a turbo motor to run say  7 to 9 psi boost ------  would have more then a little bit of get up and scoot, not to mention, lighten the fly wheel, advance the timing polish the heads junk the stock intake and make a shortram, atleast if your not going turbo, headers 2" or 2.5" exhause to a turbo muffler and some 29 MTRs and you would have a good little starting point
Thank you sir!
Great advice there!
Offline beerman
  • 339
  • Suzuki 4x4 Norway
    • www.tristania.com
« Reply #16 on: April 05, 2006, 05:27:33 PM »
on a race car i would lighten the flywheel, but on a 4x4 i would not.
it seems better (to me, at least) to have torque down low than a lot of hp up high.
Offline Hawklin
  • 109
  • If it cant be fixed with Duck Tape it aint broke
« Reply #17 on: April 05, 2006, 08:18:50 PM »
I have to agree with you there beerman, a lighter flywheel will require the engine to have to work harder to get the larger offroad tires to move. If possible I would try to find a heavier flywheel, the more momentum of the flywheel makes for quicker starts  ;D
Rob Cross
90 Tracker (sold :()
91 Toyota 4x4 bone stock other than a redneck lift(cranked T bars and a block in the rear) on 35's
