Fiberglass front fenders
  • 36 Replies
  • 7284 Views
Offline Yoak
  • 577
Re: Fiberglass front fenders
« Reply #15 on: April 07, 2006, 08:58:25 PM »
What kind of time line would it take to make them?
I just took off my old tube bumper...so why not take off the fenders also! :-X
Offline jason hutchison
  • 495
  • ZUKIWORLD Staff
    • ZUKIWORLD Online
« Reply #16 on: April 08, 2006, 03:29:21 PM »
So let's narrow this down.  I actually have a bushwacker wide body kit on my kick and I love it. It's the glue on type but they look cool.
I think there should be two options for Front fenders.  And I think they should be bolt on not glue on. I also think it should have shaved marker lights or optional marker light locations.
1. A fender with stock body lines just a much larger wheel well opening.
2. A wide body fender that is has the larger wheel opening and maybe a couple of inches wider.
I would pay 250 to 300 a set after checking toyota prices that seems to be the going rate for fiberglass fenders.
Anyone have any ideas on the rear.. Other than glue or pop rivet or other type of fastner there isn't really a good way to do the rear.
Offline tOnKa TrAcKeR
  • 264
  • support our troops
    • Cardomain site
« Reply #17 on: April 08, 2006, 03:47:55 PM »
man I wish i could find a set of those bushwackers.
Offline AJMBLAZER
  • 2166
  • Your mom.
« Reply #18 on: April 08, 2006, 04:36:29 PM »
I've never seen a glue on 'glass fender.  Are you thinking of flares?
From a friend's experience with 'glass fenders on his Ranger you need to make sure the stuff lines up and is the same dimensions from each peice to the next.  He got a set of Perry's Fiber front 'glass for his Ranger and they were horrible.  Stuff doesn't line up at all, mounting points were just wrong and off, and from side to side they fit very different.  He got it to work but wasn't happy at all.
Also remember you'll have to find a good way to ship these.  If UPS can f-up a Detroit Locker or a bumper they can F-up a fiberglass fender. :P
As for the rear, the only good way is pop-rivets, dzus (sp?) fasteners, or bolts.  That's what I've seen on Broncos, BII's, K5's, Explorers, etc setup for desert stuff.  Autofab's Bronco rears go on that way.  You cut out the fenderwell according to their specifications, drill some holes, and mount up their fenders.  There's no way to make it look pretty without doing major body work that would fall off the first time you offroaded it.
Offline BigPig
  • 276
« Reply #19 on: April 08, 2006, 07:27:59 PM »
Okay, let's see some pics of your Bushwackers.  I've heard of 'em but never seen 'em.
'89 Sidekick w/ 4.5" of lift.
Offline LBC4x4
  • 78
  • 1992 4door 3" body 1"coil spacers 31x10.5
« Reply #20 on: April 08, 2006, 08:29:52 PM »
Definatly interested in fender flairs depending on cost. I have been needing wider fenders for along time now and if they are priced like the toyota ones then I would buy a set.
Offline Uncivilized
  • 1469
    • Car Domain
« Reply #21 on: April 09, 2006, 08:15:12 PM »
I agree, I think just a pair of pre-runner style fenders, about 2" wider and a large tire cutout, similar size to zig's cutout he did on his rig. Then have a basic 2" flare for the rear, like a samurai flare(remember, it doesn't need to be cut out like the front as it doesn't turn).
I like the idea, if the price was right, and they looked good I might buy.
I also like the idea of the shaved markers, if someone wanted them, they could easily drill/cut the holes necessary to mount them(and they could put them front or rear).
« Last Edit: April 09, 2006, 08:18:35 PM by Uncivilized »
Offline ppltrak
  • 654
  • zukspeed staff
    • zukspeed.com
« Reply #22 on: April 10, 2006, 09:18:32 AM »
Here's a pic of hutch's bushwhacker kit
Offline ppltrak
  • 654
  • zukspeed staff
    • zukspeed.com
« Reply #23 on: April 10, 2006, 09:20:49 AM »
And another
Offline AJMBLAZER
  • 2166
  • Your mom.
« Reply #24 on: April 10, 2006, 04:24:50 PM »
ppltrak, so are you thinking of a flare kit like those or an actual PreRunner replacement fender?
Offline ppltrak
  • 654
  • zukspeed staff
    • zukspeed.com
« Reply #25 on: April 11, 2006, 08:33:10 AM »
An actual pre runner front fender first and then poss. rear flares later. The front is the biggest issue with the kick.
   kevin
Offline ppltrak
  • 654
  • zukspeed staff
    • zukspeed.com
« Reply #26 on: April 11, 2006, 08:44:47 AM »
What we are going to do is meet with a guy who does this for a living. He makes ranger, chevy, toyota,... kits, but nobody makes kits for our stuff. Prob. I will fund the first batch 10 and see how they sell. I'm not in the bus. of trying to make a profit off of these. We just have a conn with someone and would like to see more options for our trucks.
      Kevin
Offline kozaz
  • 168
« Reply #27 on: April 11, 2006, 10:15:59 AM »
Where do you get the kit and how much?
Could you some how add a lip to your kit and then bolt or rivet it on instead of using the glue?
Offline chet
  • 556
  • Zuki time!
« Reply #28 on: April 11, 2006, 10:43:30 AM »
I would try these guys
http://www.toyotafiberglass.com/
They are active on a couple of local boards and seem to be into the 4x4 thing. I know a friend of mine used their rear replacement panels on his 4 runner and they fit excellent.
Offline Yoak
  • 577
« Reply #29 on: April 11, 2006, 02:16:09 PM »
Keep me posted I will more than likely love to pick up on of those 10
