Which GM Alternator Application
  • 31 Replies
  • 16243 Views
Offline trackenator
  • 38
Re: Which GM Alternator Application
« Reply #30 on: October 14, 2006, 06:33:31 PM »
maybe this will help. I run dual batteries in my tracker. my second battery is located in the back of my 2dr.I do run an isolater(bought at auto zone)ALL my accesseries run off of this battery(500cca) stock alternater.I ran long wires from front to back battery mounted isolater under hood that way if my main(for starting) should fail i can switch to my 2nd. Much easier and cheaper than alt swap. good luck.
Offline BLK_ARMR
  • 175
  • Herculiner All The Way!!
« Reply #31 on: December 14, 2007, 10:31:13 AM »
Just wanted to bump this thread and  let everyone know I got the alternator swapped out.  I used a 94a 12SI GM unit.  I'll post the part number at the bottom of this post.  Everything was very straight forward.  There is a 2 wire plug on the back side on the alternator.  You will need the pigtail for this.  I read in one of the articles somewhere how to hook this up.  The red wire I jumped back to the main post on the back of the alternator.  The white wire gets spliced into on of the 2 wires that went into the plug that plugged into the back of the stock alternator.  Evidently the colors changed from year to year on the wires.  Mine was the white wire.  Pick one, doesn't matter which one.  Start by just twisting the wires together and make sure they're not touching anything.  Start the truck.  Now turn the truck off.  If the truck keeps running and doesn't turn off like it should, you have the wrong wire (I picked the black one first. LOL)  IF this happens, just pull the wires apart to kill the truck.  Splice into the other wire and you're golden.  So far, everything is working great.
Lester Number:  7294-3
Any auto parts store should be able to cross reference that number.
93 Tracker
Coated in **HERCULINER**
2pc Hard Top, Flares, 3" Body Lift, 31"x10.50" OTR Muds, 15"x8" Black "Wagon Wheels"
