Orange Rig Makeover is posted
  • 20 Replies
  • 4542 Views
Offline ZeusZuki
  • 411
Re: Orange Rig Makeover is posted
« Reply #15 on: May 19, 2006, 03:42:17 PM »
http://4wheeloffroad.com/2005ultimateadventure/131_0511_lift/
Try this link. My computer seems to be having a melt down - YOU SUCK BILL GATES , you  :-X  :-X  :-X  :-\
ZeusZuki.
Offline Mikerpm4x4
  • 2875
  • Redline... all the time!
    • www.rpm4x4.com
« Reply #16 on: May 19, 2006, 09:32:40 PM »
So to start this project form scratch, you would need the calmini lift and then heavly modify it from there.  What size are those tires.  I saw the over the bucket picture, that is very impressive, but the back diff would hit it right?  Just make a IRS to match the front then it would clear just fine. ;D
Is the 7.5 front diff the steel gv?
Great project! I could only dream if somthing like that some day.
Jeff
I wouldnt recomend a build like this for most people. It was quite intense trying to fit everything into place while keeping Camber, Caster, toe, and SAI correct. I would say it was almost overwhelming. The pic over the bucket is with the coils at full height. Ive been running my ride height about 1-2 inches over the bucket. Keep in mind my ride height is fully adjustable within a matter of seconds by just cranking on the weight jack with a 3/8 rachet. The front is a tracker 7.5 rear.
Mike
Offline Mikerpm4x4
  • 2875
    • www.rpm4x4.com
« Reply #17 on: May 19, 2006, 09:44:12 PM »
35-13.5-15 BFG Krawler
Offline Uncivilized
  • 1469
    • Car Domain
« Reply #18 on: May 27, 2006, 08:26:46 PM »
Mike -
Was the rear left alone, the front has more lift now right? - just curious if you added any extra lift in the rear to match the front..... (to make it level-ish ;) )
~Dave
Offline Maroon Monsoon
  • 876
« Reply #19 on: May 27, 2006, 09:39:16 PM »
I really really want to make my GV dual control arm someday because of your beast of a zuk
Offline Mikerpm4x4
  • 2875
    • www.rpm4x4.com
« Reply #20 on: May 29, 2006, 06:51:55 PM »
Mike -
~Dave
I did not add any lift to the rear. I can adjust ride height in the front with a ratchet, so how much lift I have depends on how I want it set up.
Mike
