Roll cage
  • 37 Replies
  • 9430 Views
Re: Roll cage
« Reply #30 on: February 09, 2005, 06:29:58 AM »
zukipiolit i'm still waiting for those pics. this weekend is build time i 5 friends comming to help. not just on the roll cage.
Hang on let me see if they are here.
Offline tracker8wr
  • 568
  • THE BIGGER THE BETTER
    • my home page
Re: Roll cage
« Reply #31 on: February 09, 2005, 06:43:03 AM »
OK
COOL
4 1/2 body
Coil spacers
cheap but effective
31" LTB Swampers
Re: Roll cage
« Reply #32 on: February 09, 2005, 06:54:57 AM »
Here U go  :)
Top View:
Back View: Uprights allow for full movement of factory seat and stock seatbelt locations.
Another rear view: Notice Sami Wind jammer rear window ( does pull tight but not tight in picture)
Front view: Legs are a bit annoying at first but once I got use to it I like having the brace to sit my leg on while riding to hold myself in place tighter.
I plan on doing away with the rear seating all together (now I put the seat in when needed) and just use the rear for cargo. When I do this I will add cross supports to the middle hoop and a harness instead of the factory seatbelt.
« Last Edit: February 09, 2005, 06:56:12 AM by Zukipilot »
Offline tracker8wr
  • 568
    • my home page
Re: Roll cage
« Reply #33 on: February 09, 2005, 07:00:52 AM »
did u weld in ur backing plates for your mounts or did u use backing plates. that rear window is sweet.
« Last Edit: February 09, 2005, 07:02:24 AM by tracker8wr »
4 1/2 body
Coil spacers
cheap but effective
31" LTB Swampers
Re: Roll cage
« Reply #34 on: February 09, 2005, 07:19:21 AM »
The entier cage is bent and welded into place. The mounts to the body are welded to the cage then bloted to the body by sandwiching the floorboard between two peices of plate of different sizes (to keep from sheering off). When I do the middle hoop support I am also going to tie the cage directly to the frame.
Re: Roll cage
« Reply #35 on: February 09, 2005, 07:28:21 AM »
The rear window just happned to fit. I tried the Kick/tracker windo and it would not work with the roll cage. So I use a Kick Bikini Top, The Sami rear window and a Kick Duster Deck cover cut to work with the rear loop.
Offline CuriousKid
  • 31
  • I'm Just Curiously Inquiring...
Re: Roll cage
« Reply #36 on: February 12, 2005, 02:49:31 PM »
So which would be better, a Calmini Full Cage, or a custom rear-cage like Mike's?
Offline tracker8wr
  • 568
    • my home page
Re: Roll cage
« Reply #37 on: February 13, 2005, 01:38:22 AM »
well this was mostly about how big the driver is i'm 6'4" 330lbs so a full cage would take up to much space. that is why i'm doing a custom rear cage.
4 1/2 body
Coil spacers
cheap but effective
31" LTB Swampers
