Soild axel conversion
  • 18 Replies
  • 9270 Views
Offline 00SuperTracker
  • get er done
Re: Soild axel conversion
« Reply #15 on: June 23, 2005, 04:48:41 PM »
Thanx 4 the new info I will try to post the pic of my tracker and post the future build as it happens because there will be  more 2 follow as they get older.
00SuperTracker
Offline red_baron
  • 108
  • little red vit
    • surrey zuki society
« Reply #16 on: June 23, 2005, 10:10:58 PM »
hi
i'm using the axles from a 87 toyota pick up (hilux over here)  after measuring up, the spring mounts line up exactly with the chassis rails on the front and the  radius arm mounts on the rear.
i've only got to extend the front of the chassis and make a new rear crossmember for the rear.
fingers crossed.
Offline Uncivilized
  • 1469
    • Car Domain
« Reply #17 on: June 23, 2005, 10:36:25 PM »
I was speaking to someone last night with a 00 tracker, we were talking lifts and he mentioned he had seen a drop kit for the rack, has anyone heard of this? If there is, that would make the swap a little easier.
Offline explosivo
  • 3157
« Reply #18 on: June 24, 2005, 11:45:39 AM »
I'm still going to suggest that you swap out your box. Rack and pinion with a solid axle isn't the best of solutions :-/
omghi2.us[/url]
