2wd Ford F-150 Shocks
  • 17 Replies
  • 4010 Views
Offline TysonS
  • 383
  • www.funinbc.com
Re: 2wd Ford F-150 Shocks
« Reply #15 on: July 05, 2006, 02:46:37 PM »
well, i have been out mesuring at full flex and full droop without the shocks on and i will be able to run these shocks stock.  ;D only have to add a 1/2" spacer to the bump stop.  Full comresion on the stock springs is 14" and the ford shocks are 14" compressed. And they are 24.5" extended and the stock shocks are 18" extended.
I'm going to get about 3" of lift with areostar coils and coil spacers if needed. And a 3" ball joint spacer ofcourse.
YOU MUST GET THE 2WD SHOCKS    4WD's ARE TOO LONG!!
Offline da_tub
  • 307
« Reply #16 on: July 06, 2006, 05:14:43 PM »
areostar springs fit in zuks? if thats the case i should put a set in the rear of mine.. .will that work? have 1.5 spacers in the front and back, but if i can put those van springs in i'll take the rear spacers out and the bigger coils in.... am i crazy? or will this work... it's a 91 four door
91 four door ,and some stuff
Offline TysonS
  • 383
  • www.funinbc.com
« Reply #17 on: July 06, 2006, 05:48:13 PM »
it might work.  how bout this,  early next week i will take some pics of my areostar spring swap and see how much lift I get and if they fit good ;)  Then if you like the look of it you can go and buy some areo's and givr
