SUZUKI SIDEKICK 1.8
  • 63 Replies
  • 22430 Views
Offline hcgalvin
  • 1695
    • Granite Path
Re: SUZUKI SIDEKICK 1.8
« Reply #45 on: February 02, 2005, 06:33:44 AM »
Let's see...
1995 Suzuki JX with a 1.6L 16 Valve engine.
  • Calmini Front Winch Bumper
  • Calmini Rear Swing-Away Tire Carrier Bumper
  • Calmini 6" suspension/body lift
  • Calmini Steering Stabilizer and Truss
  • Calmini Full Belly Armor
  • Calmini Anvil Axle Housing
  • Calmini 5.83:1 Ring & Pinions
  • Calmini 4.24:1 Transfer Case Gears
  • Calmini Performance Exhaust System
  • Calmini Performance Sport Cage
  • Centerforce Clutch
  • Warn M6000 Winch
  • Warn Premium Hubs
  • Warn Hub Fuses
  • ARB Air Lockers - Front & Rear
  • ARB Compressor
  • Safari Snorkel
  • Spidertrax Custom Rock Sliders
  • Rockstomper Synthetic Winch Line
  • Between 10 and 20 Solid Brass Bells
  • K&N Air Filter
  • Heather's Bikini
  • Pioneer Premium CD Player
  • Infinity Reference Speakers
  • 15X8 Steel wheels with 2-3/4" Backspacing
  • Goodyear Wrangler MT/R's 31 X 10.50
  • Padded headrests from my 1995 Suzuki Sidekick JLX 4-door
Kewl, Updated.
Heather Galvin
Offline Bobzooki
  • 1754
  • Web Wheeler
« Reply #46 on: February 02, 2005, 06:45:55 AM »
Kewl, Updated.
You ROCK!  Thanks girly girl!  And looking at the pics, WOW is my hair a lot longer than last year at EJS!
Bob
Tahoe 24' Fish-N-Fun Tritoon
115 HP Mercury outboard
Offline hcgalvin
  • 1695
    • Granite Path
« Reply #47 on: February 02, 2005, 06:48:38 AM »
No Prob, anytime you have a change or want me to put more pics out there, send me the info!
Heather Galvin
« Reply #48 on: February 02, 2005, 03:44:13 PM »
The conversion was ...tough... but it was a learning experience. It STILL IS. We're still working on getting it rolling with the new Toy axles.  (Waiting on OTT)
Waiting on OTT?
I thought you already had a T-case done?
Problems?
Do tell, don't be shy. ;D
Inquiring minds need to know ;D
Offline hcgalvin
  • 1695
    • Granite Path
« Reply #49 on: February 03, 2005, 12:09:39 AM »
Waiting on OTT?
Problems?
Nah, waiting on FJ80 steering.
Heather Galvin
Offline Suzuki1.8
  • 283
  • Tires so low looks like i'm riding on blades
« Reply #50 on: February 03, 2005, 02:04:15 AM »
Holy crap I was just reading. Is it true sidekick sports have 5.12 gears in them? That is crazy i put 5.13 in my bronco and that is considerd pretty damn low for a v8 rig. What is the normal gear ratio in sidekicks?
« Reply #51 on: February 03, 2005, 02:18:11 AM »
That is normal gear ratio ;) 5.12 stock gearing for 5 speed Kicks. Our t-case's and Trans are not as low though.
Offline Suzuki1.8
  • 283
« Reply #52 on: February 03, 2005, 03:19:23 AM »
So techinaly speaking wouldn't regearing the tranmission with lower gears or the t case, and keep the axles stock be stronger. Because the lower the gears go the weaker they get due to small pinon. So instead of regearing axles wouldn't a t case regear be stronger since they already have low gears?
Offline Bobzooki
  • 1754
  • Web Wheeler
« Reply #53 on: February 03, 2005, 03:25:08 AM »
There is no product on the market for re-gearing the high range (which is 1:1) on a Track/Kick.  You can re-gear LOW range, from 1.8:1 down to 4.24:1 - this is GREAT.  But with bigger tires, for better highway performance, regearing the diff's is the only option - so 5.83:1 it is!
Bob
Offline Suzuki1.8
  • 283
« Reply #54 on: February 03, 2005, 03:56:38 AM »
So there transfer case is not like the sammy were you can get twin cases or have a low 2 wheel kit?
Offline Bobzooki
  • 1754
  • Web Wheeler
« Reply #55 on: February 03, 2005, 04:00:08 AM »
Well, You CAN put in 2 transfer cases, and you CAN get a 2-lo for the Sidekick transfer case but it's not like on a sammi, where lowering the lo range also lowers the hi range.  You can put a Sammi tcase behind the Kick - Nate & Heather have 2 tcases, and adapters from OTT.
Bob
Offline Suzuki1.8
  • 283
« Reply #56 on: February 03, 2005, 04:04:49 AM »
Has anyone ever put a atlas 2 on a sidekick? I run a 4.1 altas 2 on my bronco and you can pretty much get any hi range or low range you want.  That is some good info though on the transfer case gearing. I keep learning new things about these everyday. Makes me love me sidekick even more. : :)
« Reply #57 on: February 03, 2005, 04:13:45 AM »
Isn't that a divorced T-case set up? If so I dont see why you could not fab up something to work :-/ But I have not heard of one in a kick before.
Offline Suzuki1.8
  • 283
« Reply #58 on: February 03, 2005, 04:23:57 AM »
no atlas can work as a divorced or mated. They make adpoters for all kinds of vehicles. I just don't know if they do for suzuki.
Offline Suzuki1.8
  • 283
« Reply #59 on: February 03, 2005, 04:30:37 AM »
Well Thankyou for all the information and advice. I think i have decied which way to go on my suzuki. I know most of you guys will mock me for my decesion. But I am going to put 20 inch rims on and modify the calmini lowering kit to fit my sport. I also talked with regulate in utah about getting a turbo. I'm also going to have the head ported and polished and the blocked bored out. I know this is not the way 99% of you would go but i need something that i can drive 100 miles a day and be comfy and get good fuel mileage. I already have two vehicles for off road. In fact one that is only good off road for it is to tall and get 6mpg. I will post pictures as i go. So while you guys are taking on the jeeps. I'll show the hondas how suzukis do it. let me know what you guys think or if you have any idea?
