Anyone painted the grill on their Tracker?
  • 27 Replies
  • 5734 Views
Offline hman1991
  • 53
Re: Anyone painted the grill on their Tracker?
« Reply #15 on: September 19, 2006, 06:46:54 PM »
is that how much u could paint with a gallon, or did you have some left? did u interior?
DAC1138
« Reply #16 on: March 11, 2007, 09:51:24 PM »
I was going to paint my grille and the section above the grill. problem is, i have a brush guard I cant figure out how to get off to get the grille off. so now I have a question for you folks. How to i remove the grille and the small body piece above the grill? the piece above it is the part the has the latch for the hood. it's the peice between the hood and the grill. I'd like to paint this too, but this is the part I need to remove to get the grille guard off to get to the grill to remove.
as stated in my signature, i have a 96 sidekick JX 4 door. should the process be pretty much the same for most geo/suzuki rides?
Offline jzap
  • 515
  • How difficult can it be?
« Reply #17 on: March 12, 2007, 05:47:44 PM »
The header bar above the grill is held on by four (i think) screws that go into the backer that holds the lights and two screws on a brace in the center of the header.
Unfortunately, you have to take the grill out to get to the screws that hold the header on.  On a '96 Tracker, the grill is held on by one screw to the top of the center brace and two screws at the bottom of the grill.  You can see all the screws looking at the grill straight on.  (A Kick has two more screws on the "ears" that fit between the fender and the bumper.)
I found it easier to take out the screws at the bottom of the brace.  Once you take all the screws out and unclip the hood latch cable, the header, center brace, and hood latch easily lifts out as a unit.
Jim Z.
66 Apache camper
DAC1138
« Reply #18 on: March 12, 2007, 05:55:15 PM »
Thanks for the tips. I found the screws under the hood previously, but after unscrewing them I was still unable to remove the piece. That's probably because I didnt remove the grill with the 1 (or 2) screws. I'll try it all again to see if it all can be removed with the new advice. Thanks.
Offline R.Cadett.
  • 106
« Reply #19 on: March 17, 2007, 04:58:25 PM »
so you want it to look like this?    the cirlces in the second photo are two other screws that need to be removed if i can remember correctly not sure if you tried that. let us know how you make out though
95 Completely Stock Sidekick, i added fog lights , and thats about it
« Reply #20 on: March 17, 2007, 05:53:15 PM »
I'm perty sure those two circles are for headlight aiming.
Offline R.Cadett.
  • 106
« Reply #21 on: March 17, 2007, 06:09:23 PM »
really? i coulda sworn when i took everything off the front there were two screws or some sort of pins the had to be popped out, but i cant really remember that well so you are probably right.
« Reply #22 on: March 17, 2007, 07:18:45 PM »
This is what is on my 97 4dr
The clips are a PITA to get out and not break.
be carefull
Offline Carnage
  • 2453
« Reply #23 on: March 17, 2007, 11:47:54 PM »
thats a pretty kewl lookin grill HR
(dont see many of those)
ur right i reckon
both our 96s have no screws on the bottom
those two circles ARE for headlight aiming.
(and those clips ARE a PITA)
« Reply #24 on: March 18, 2007, 12:04:23 AM »
thanks, came with the car ;) ;D
So many differant grills avilable.
Geo, GMC, Suzuki, pontiac, 88-99
Offline sklope
  • 135
  • BUSHWACKER
« Reply #25 on: March 18, 2007, 07:08:03 AM »
Not meaning to steal this thread, but I need the clips that hold the grill in place. I busted my grill and want to replace it, but I hate to buy a new grill and then hold in place with tie wraps! Anybody know where I can buy these clips other than the junk yard?
* '96 Tracker
* 2" Sky body lift
* 235/75/15 M/T's
* Custom front and back bumpers
* Durabak exterior coating (bed liner) * '07 chevy silverado "wail tail" tailgate cover (custom cut to fit)
« Reply #26 on: March 18, 2007, 11:34:21 AM »
either a dealership or HAWKS
Offline ghd23
  • 406
  • 1990 Tracker softop, Detroit Mi.
« Reply #27 on: March 18, 2007, 04:20:05 PM »
Before and After.  ;D  ;D  ;D
If I Can't Weld It          It Can't Be Welded
