Samurai Motor Swap
  • 19 Replies
  • 6737 Views
Re: Samurai Motor Swap
« Reply #15 on: October 27, 2009, 05:02:10 PM »
does any one no if they make a adapter plate for a 78 nissan 4 cylinder motor to adapt to a suzuki transmission
« Reply #16 on: October 31, 2009, 02:32:00 PM »
what intake gasket do you use? the  sammy or the tracker? they ARE different gaskets.
« Reply #17 on: October 31, 2009, 03:34:32 PM »
You would have to adapt the Nissan intake to work with your existing fuel system.  I don't think the Sammy 1.3 intake is going to be a direct bolt up.  :)
No idea on the adapter plate, but I doubt it.  You would probably be better off using a Nissan 2wd transmission and using a modified jack shaft to go into the transfer case.
« Reply #18 on: November 01, 2009, 06:23:25 PM »
oooh race?  As some of you know, I never run my motor hard.
Offline dupont#24
  • 48
  • Deer hunter
« Reply #19 on: November 01, 2009, 07:32:50 PM »
if you decide to go with the 1.6 8valve I have a 94 harness and computer for sale I don't know how many models this will work on .175.00 for both.If you want to stay fuel injection
