Rear shocks ( Crow Vic, FJ-60 ??)
  • 31 Replies
  • 8341 Views
Offline r3cc0s
  • 321
Re: Rear shocks ( Crow Vic, FJ-60 ??)
« Reply #15 on: October 07, 2006, 03:45:09 PM »
Installed the crown vic shocks and used 3/8" plumbing threaded sleeves from home depot (made by Watt)
threw it into the back of my now 2" rear lifted trucklet and gave it a ride...
surprisingly for my 2.0L superbase tracker (no power nothing, not even abs/power locks nothing)
It is fantastic, it dampens just fine and in fact feels great
Offline ngrover
  • 131
« Reply #16 on: October 07, 2006, 07:10:41 PM »
cool man that was fun. I left when you guys were thinking of doing the front... i guess another time?
I managed to pick up a set of shocks for a rear 1/2 ton ford van and installed my rear lift today as well with diggers spacers (took all of 45 mins). The shocks bolted in like stock, both the ends were identical and no shim was required. In terms of height they are perfect (have an extra 2 and a bit inches of travel and have the same compressed length). If they were any longer they would put tension on the hand-brake cable when the wheel is fully dropped. I took it for a spin and I'm quite happy. It does ride harder than stock but so far I like it and don't consider them too hard. I'll give a better review once I have used them off-road. I took pics and I'll post them here in the morning.
« Last Edit: October 07, 2006, 07:12:35 PM by ngrover »
2000 Suzuki Grand Vitara, 5spd. 2.5 inch lift, 225/75R16 AT's
Offline ngrover
  • 131
« Reply #17 on: October 08, 2006, 09:26:26 AM »
before and after (2 inch coil spacers and ford van shocks)
Offline ngrover
  • 131
« Reply #18 on: October 08, 2006, 09:28:19 AM »
rear shocks from 95 ford full size van vs stock suzuki
Offline ngrover
  • 131
« Reply #19 on: October 08, 2006, 09:02:32 PM »
aight, who am I kidding. I drove around for a while today and concluded the ride was to harsh with the ford shocks.. I took em off and they still look new so i'll return them and try something else. it's a shame because the specs were otherwise spot on.
Offline bzzr2
  • 1011
« Reply #20 on: October 09, 2006, 04:52:24 PM »
can't help with the size.. i don't know what the diameter was, i just brought the bolt and the shock with me and looked for whatever was a good fit.
....... oh, just read the 2nd page...  glad you found what you needed!
« Last Edit: October 09, 2006, 04:55:46 PM by bzzr2 »
09 taco reg cab short box 4x4
Offline ngrover
  • 131
« Reply #21 on: October 09, 2006, 05:15:27 PM »
so glad i returned the ford van shocks. I got some rear shocks for a 1990-1995 Toyota 4-Runner.... man am I happy about how they ride. I would say they ride better than stock. They feel a little more supple over the small stuff but ramp up over the big stuff. I drove around in the dirt at slow speeds and they seemed a lot more responsive but when driving at speed on the road they felt a lot like stock.... absolutely love em. All told I had the rear end a-part three times this weekend but it was worth it to dial in the ride. I'll make a post later regarding part numbers / how-to etc.
« Last Edit: October 09, 2006, 05:33:55 PM by ngrover »
Offline ngrover
  • 131
« Reply #22 on: October 09, 2006, 05:20:19 PM »
couple shots of the bottom mount. I had to make a Rona trip to get some shims and a bolt. The bolt is imperial and ever so slightly larger in diameter than the stock metric one (about a finger nail width). The two shims fit the bolt and the shims fit inside the rubber perfectly.   drilled the shock bolt holes on the vehicle itself but it was such a slight amount a 2 minute file job would do the trick.
Offline ngrover
  • 131
« Reply #23 on: October 09, 2006, 05:21:29 PM »
the drill job.. You'll only need to do this if you use the same 1/2 inch bolt and shims like I did. I could have quickly filed enough metal to fit the bolt. The size difference is so slight that if I ever needed to I could go back to using the stock metric bolt.
« Last Edit: October 10, 2006, 01:06:10 PM by ngrover »
Offline ngrover
  • 131
« Reply #24 on: October 09, 2006, 05:22:17 PM »
all buttoned up
Offline ngrover
  • 131
« Reply #25 on: October 09, 2006, 05:26:30 PM »
Monroe part number #32248 (1990-1995 Toyota 4-Runner)
ends: S4/L3
compressed length: 12.875
extended length: 20.875
you won't want a longer shock or it will strain the brake hose when extended on the passenger side. I had to undo the two inner-most clips holding the rear hand-brake cable to allow enough slack when the wheels were fully dropped. Otherwise perfect. These shocks allow the most wheel travel possible.
I recommend em!
« Last Edit: October 09, 2006, 05:34:22 PM by ngrover »
Offline JDMCRX
  • 1110
  • 02 Grand Vitra Pimp lol
« Reply #26 on: October 11, 2006, 08:05:36 PM »
One tip put bigger washers on the outside of the bushing. It will pop out trust me and jam up. Ill take a pic tomorrow
01 GRAND VITARA
Offline diftoyota
  • 253
« Reply #27 on: July 06, 2012, 07:22:28 AM »
how the 4-runner shock doing for you now? does it still work good? planning of getting a set to put on with my jeff 2" lift
Offline bzzr2
  • 1011
« Reply #28 on: July 06, 2012, 04:48:38 PM »
hey i suggest looking for the thread where i talked about running ford thunderbird shocks, they were longer and rode great and direct bolt up..  i'm too lazy to look and don't even have a zuk anymore!
Offline diftoyota
  • 253
« Reply #29 on: July 10, 2012, 11:18:02 AM »
what year thnderbird was it?
