slipyoke elimimateors?
  • 21 Replies
  • 4281 Views
Re: slipyoke elimimateors?
« Reply #15 on: January 14, 2005, 03:01:47 AM »
Use a Kick flange, bigger bolt pattern,
remember, you need to have new DriveShafts
made so there will be some articulation in the
driveline, or bang  :o
Offline explosivo
  • 3157
« Reply #16 on: January 14, 2005, 11:53:57 AM »
Yep yep. Slipshafts are gonna be a must with the SAS.
omghi2.us[/url]
Offline mesjr2004
  • 422
« Reply #17 on: January 15, 2005, 01:44:31 AM »
so im assuming the splines on the trackick flanges are the same as the transfer case slipyoke? is the ceal the same ?
« Reply #18 on: January 15, 2005, 09:04:42 AM »
I don't remember if I measured them
or not, no worry, I get whatever is needed
at the seal store, even metric sized stuff.
Offline zookiemike
  • 474
  • $,reppin Michigan,$
« Reply #19 on: January 15, 2005, 10:20:35 AM »
When my buddy did his sas on the tracker, he just used a slip shaft and didn't have any problemes with the the slip yoke comming out on the front.
Offline Natebert
  • 1098
« Reply #20 on: January 16, 2005, 04:04:07 AM »
So a slip yoke and a slip shaft on the same drive line?
~Nate
« Reply #21 on: January 16, 2005, 04:27:05 AM »
under the right conditions, I could see a
uhh-ohh happening, but hey, if you are
comfortable like that ........
