Cold Air
  • 25 Replies
  • 7089 Views
0 Members and 29 Guests are viewing this topic.
Re: Cold Air
« Reply #15 on: November 24, 2004, 01:56:22 PM »
how do the air horns work?
You can hear those things inside a Semi Truck
at 65 MPH, I'd say they work good, better than
the stock beepers that you can't hear inside your
Trucklet at 55 MPH
;D
spinaltap
All I can say is WOW
« Reply #16 on: November 25, 2004, 01:29:31 PM »
WOW!! What a difference the intake makes on the top end. When I leave work I have to turn onto the highway with no merge lane...so I floor it through the gears to get up to speed....normally the thing starts to run out of steam a little past 5K rpm...now, 6K and its still pulling ;D An added bonus is the induction roar along with the full exhaust its just shy of orgasmic :o I don't think fuel mileage has increased all that much but it did seem to be a bit better, maybe saved a litre or so...but man that top end performance is worth it. I was able to accelerate up a couple of steepish hills in 5th!! (It used to just bog down and lose a couple mph on these hills) Now I'm just panting for the rebuilt to be finished...with the Calmini cam, slight plane, port and polish this thing oughta be just fine :)
Offline 92Sidekick4x4
  • 1456
Re: Cold Air
« Reply #17 on: November 25, 2004, 04:33:32 PM »
http://www.puresuzuki.com/air_intake_system.htm o was thinkin of somehting liek that but i think i coudl probly make one like yours looks pretty cool cuz the way i understand if it can pull cold air it will get more power? im thinkin that it could pull the cold air through the holes where it leaves by the strut tower things, would this work?
spinaltap
Re: Cold Air
« Reply #18 on: November 25, 2004, 11:50:50 PM »
Yeah I was asking Chris at Calmini about that intake...he said they would be taking pre-orders in December (I asked in October). It looks to be a good piece and I'd be interested to hear about how it performs.
This is the pic of the one I bought from ebay, they had it mounted pointing down toward the back...I suppose to get air from the original air inlet.  I decided to mount mine facing forward as a lot of air gets through the gap between the hood and fender. Maybe in Spring I'll fab up a box around it and install a hood scoop to feed the air
These intakes are selling on ebay for about $33 CDN right now...
I should have some time this aft to get those measurements for you.
« Last Edit: November 25, 2004, 11:52:31 PM by spinaltap »
  • 1456
Re: Cold Air
« Reply #19 on: November 26, 2004, 11:57:28 AM »
k cool, whats the link for the ebay auction?
Offline Blasted
  • 63
  • Yea.. its a Kick.. Keep dreamin.
Re: Cold Air
« Reply #20 on: November 26, 2004, 12:10:57 PM »
You can save some expense by just ordering a K&N that will attach right to the end of the intake. Cost me about $35 Canadian.  Good power gains with premium fuel and some timing tweaking.  Setup didnt like hot weather though...  Oh well..
93 Sidekick 2Dr.  2"body lift.  30" Tires. 1.5" Coil spacers. 4 door coils. 2"strut spacers. K&N Factory replacement filter. 2.25" Cat back, with glass pack.  Custom ground High torque Cam shaft. And CB for talkin trash.
spinaltap
spinaltap
Re: Cold Air
« Reply #22 on: November 27, 2004, 06:15:56 AM »
SpinalTap
would u be able to measure it for me? like the length befroe the bend and after the bend? what diameter is the pipe?
TIA
The measurements are 7" before the bend, then its about 6.5" to the end from there. The OD is ~2.75"
  • 1456
Re: Cold Air
« Reply #23 on: November 28, 2004, 03:12:47 PM »
ya cuz it also pulls hot air form the manifold
  • 1456
Re: Cold Air
« Reply #24 on: November 28, 2004, 04:58:38 PM »
thanks alot for that, gonna go get some pipe tomrmow hopefully, my brother has a old kn cone filter i can have so ill give it a try
spinaltap
Re: Cold Air
« Reply #25 on: November 29, 2004, 05:31:23 AM »
Cool...show us how it turns out :)
