4DR Kick: To B(odylift )or to not to B(odylift). That is my question...
  • 30 Replies
  • 9066 Views
Offline cj
  • 1276
  • I drive a really big ATV
Re: 4DR Kick: To B(odylift )or to not to B(odylift). That is my question...
« Reply #15 on: November 18, 2007, 12:43:30 PM »
I had some thoughts of doing 2.5 susp and maybe a 2" body....
Are you worried about lifting the truck more than you absolutely have to? Sidekicks are quite stable trucks. The wheelbase is only 14" longer than the width of the axles. I asure you they are quite difficult to tip over. Unless you are into extreme rock crawling in which case you can tip most anything over if you try hard enough.
I tipped mine and it wasn't extreme rock crawling although I will admit it was a wacky line  :-[
Keep in mind that it is not on;y the diameter of your rubber but also the width and the rim offset/backspacing that has an impact on what is needed o fit it.
Suspension lifts do not allow bigger rubber to fit at full compression but extending the  bumpstops can. Body lifts give more space to fit bigger rubber although I am not a great fan of them they do have a time and a place and with the Kick they also help get the rockers away from the ground which isn't a bad thing. IMHO they should also be solid spacers.
The 4dr has an issue with the size of the rear wheelwells which makes it hard to fit big rubber but Mike Hagen's rear rotation mod will help with that if you run out of space there.
I have run 33x9.5 on stock rims with a 2" body and 2.5" suspension lift with minor trimming inside the wheelwells and also 31x10.5 with the same lift but a touch less backspacing on a 4dr. On a swb I have run some narrow 32's on stock offset 16" rims (Kick Sport) with just a Calmini 3" suspension and no trimming in the front and just a touch on the rear bumper to clear the lip. As you can see there are a number of combinations available to achieve an outcome. My approach now is to get the size rubber I want with the least amount of lift. If that means taller but narrower rubber then I will look at that. The beauty of these rigs is that their small size and weight means that they don't necessarily need as wide a rubber as the big rigs do so if you can leave the looks part out of the equation then there a some options out there that will increase your clearance under the diffs without needing to go crazy to fit them although the terrain you drive will have a bearing on the width you may need to run.
Bandit02
« Reply #16 on: November 20, 2007, 05:02:02 PM »
Yea, you will find that there is not much droop in the front. This is the only thing I really don't like about my setup. I did have to trim a little metal out of the rear of my front fenders to stop rubbage there, you just have to be willing to cut and beat on the inner fenders until you don't rub anymore. Even though this is a very inexpensive and cheap way to a little more lift, I have pushed mine to it's limits and it does great, but I do have my eye on a couple trails that sill take at leat some 32-33's and Lockers, so, I have more modding to go  ;D
« Last Edit: November 21, 2007, 03:38:03 PM by Bandit02 »
Offline 96Kicker
  • 1043
  • http://www.zukiworld.com/forum/gallery/3710_25_10_
    • www.myspace.com
« Reply #17 on: November 20, 2007, 08:30:00 PM »
4 words....STAY AWAY FROM BODYLIFTS
<a href="http://s220.photobucket.com/albums/dd126/fletcher9160/?action=view&current=Zuktahgreenblur.jpg" target="_blank"><img src="http://i220.photobucket.com/albums/dd126/fletcher9160/Zuktahgreenblur.jpg" border="0" alt="Zuktah club sticker"></a>TJ
#801-554-3281
96 kick 4 door with custom 3 inch susp lift and pre runner front bumper,2 inch bod
Offline sidekicksrock
  • 416
  • Lil Suzys Dad
« Reply #18 on: November 20, 2007, 09:44:14 PM »
You have to tell us why Fletcher. I have had a body lift on my truck since 95 and I have had no problems with it at all. Infact the kit on lil Suzy is the first body lift ever put on a Sidekick. 12 years same truck no problems
Student of Now Master of Then
Offline Element
  • 1902
  • LillyKicker
« Reply #19 on: November 21, 2007, 05:02:54 AM »
I will say that Fletcher has a good reason to say that... He added a 3" to an old rig of his. I dont like the 3" I am considering 2" body lift. I have ordered some goodies for my kick and can't wait to build it up!!!
I see many bumper lifts for 1 and 3" body lifts... Am I able to get a 2" to raise my bumper?
zUkTAH
U4WDA
Offline 96Kicker
  • 1043
    • www.myspace.com
« Reply #20 on: November 21, 2007, 08:30:06 AM »
Bodylifts put to much leverage on the mounts, they are very dangerous and a good way to realy destroy the strength of the body.I have had two bodylifted vehicles.A 94 2door kick and a 1987 ford ranger.Ya they allow for you to put bigger tires on, they look cool and are afforadable.On the ranger I busted mounting bolts left and right and finaly the mounting holes through the body got so beat up I have to  just take the body off and go as a trail only rig. On my Tracker the bolts came loose every outing, In real flexed out situations the body whould creek and crack and make all kinds of noises like it was going to fall off the frame.
Then I remember the big as ass gap between the body and frame.....UGLY  and how about the frame how it sticks so low than body under the rocker pannels...........UGLY.......Ill never ever do a body lift again. I will say this, when I installed my twin sticks and 4to1 t case, it was much easier with the body lift.
Just be patient,save your coin and go with Toyota Axles and Trail Tough Trail slayer kit.
These vehicles I listed above were not on the street that much and I wheeled the crap out of em.
Maybe as a street vehicle a body lift might be ok, but offroad never.
« Last Edit: November 21, 2007, 08:33:24 AM by fletcher »
#801-554-3281
  • 416
  • Lil Suzys Dad
« Reply #21 on: November 21, 2007, 11:14:44 AM »
fletcher, you make some good points. The 2" body lift on lil Suzy is made from 2X3 inch box tubing. It is fairly heavy duty and I put it together using grade 8 hardware. I have not had any problems with the bolts coming loose or squeaking, and the truck has seen a lot of off-road travel. You may be right that 3" is to much, it is possible that it does put to much stress on the points. The Sidekick frame does flex a lot and the farther you move the body from the frame the more stress is going to develop.
Agreed, My next project is going be a 16V 4 door auto. It will be getting a 4 link SAS setup and 33's. It will not be getting a body lift because all the lift needed can be incorporated into the suspension lift.
Offline crikeymike
  • 713
    • http://www.wazuks.com
« Reply #22 on: November 21, 2007, 01:21:32 PM »
I just went and checked the bolts on my 2" RRO body lift the other day.  I couldn't get any of them any tighter than they already were.  It's been a little over 2 years now since I first installed it, and haven't had a problem, with the exception of the silly little mounts that are supposed to support the frame/body up near the rear coil spring mount.  Those didn't hold in very well.
When Fletcher first said he was busting mounts and that, i figured he lived on the east coast with bad rust situations, but then i saw his profile, and he's in utah.  I personally haven't ever seen frame or body mount problems on a tracker/sidekick, other than those really rusty ones from canada and the east coast.
I do agree that I wouldn't do a body lift, unless i had to, and on my vehicle, i felt it was pretty much a requirement.  The gaps are horrible though.
1993 4-door Sidekick
4.24:1 t-case
Offline 96Kicker
  • 1043
    • www.myspace.com
« Reply #23 on: November 21, 2007, 04:58:07 PM »
I tried the Body Lift experience..TWICE and the picky person I am, I just dont care from them. Maybe a 2inch will not be as bad as my 3 inchers. If I need more tire room......get the dremel out and do a clean cut on the fenders, then rap it with some black rubber molding to cover up the bad spots.
#801-554-3281
Offline Element
  • 1902
  • LillyKicker
« Reply #24 on: November 21, 2007, 07:54:05 PM »
Well, The 2" are high density poly I think... So no square tubing... Fletcher, I am PMing you something...
zUkTAH
U4WDA
Offline Element
  • 1902
  • LillyKicker
« Reply #25 on: November 25, 2007, 07:06:08 AM »
Well thanks everyone who voiced an oppinion on this matter. I have (nearly) decided on my course of action for my 4dr. I will be doing the RockMolester lift ( http://www.pirate4x4.com/forum/showthread.php?t=444978 ).  This will allow me to run 30" tires. I believe this will be perfect for its intended use. Now I have to start planning for other things....
Oh The Insanity!!!! ;D
zUkTAH
U4WDA
erik the red
« Reply #26 on: November 27, 2007, 06:55:00 PM »
Sky's 2 inch body lift with OME coils, shocks and struts. Gives you about 4.5 inches of lift without an aftermarket front bumper. I am running 30x9.5x15 Cooper Discoverer STT's on 15x7 steel rockcrawler wheels. Works great so far!! My .02
Offline Element
  • 1902
  • LillyKicker
« Reply #27 on: April 12, 2008, 09:24:22 PM »
Well, I did the RRO 2" bodylift. I will post a pic tomorrow when it is light out!!!  I know you can do a 3" gastank lift...  Will it work the same for a 2" body lift? More mods to come!!!!
zUkTAH
U4WDA
  • 416
  • Lil Suzys Dad
« Reply #28 on: April 14, 2008, 07:03:04 AM »
Hi congradulations on the lift. The gas tank lift will not work on a 2 inch lift. You need the full 3 inchs to fully raise the tank. I have a 2.5 inch lift on lil suzy and when I raised the gas tank on her I had to spacer down the front of the tank for clearance. Perhaps you can do the same I don't know. Honestly I don't think so, I think a full inch less will be to much, and the gas tank will sit at to much of an angle.
The reason it will not fit is because of a small box on top of the gas tank. It might be possible to move it, or cut or hammer some clearance into the floorboard to make it work.
Offline Element
  • 1902
  • LillyKicker
« Reply #29 on: April 14, 2008, 08:51:09 AM »
Thanks for that info.... I will research further...
Also, it feels like I am sitting in a highchair now...lol
zUkTAH
U4WDA
