Help, Sidekick info 101.
  • 15 Replies
  • 4622 Views
Offline ilikemud
  • 35
    • 4X4
Re: Help, Sidekick info 101.
« Reply #15 on: December 31, 2007, 05:04:56 AM »
here you go
 1995 SUZUKI SIDEKICK JX
 L4 1.6 Liter FI
Oil Filter                      : fram Extra Guard PH4389
Air Filter                      : fram Extra Life III CA7617
Fuel Filter                    : fram Fuel Filter G6678
PCV Valve                   : fram FV278
Distributor Cap             : bosch 03380
Rotor                         : bosch 04273
Spark Plug Wire Set     : bosch 16V 09360
Spark Plug Wire Set     : bosch 8V  09240
Spark Plug                  : bosch Platinum IR Fusion; 16 Valve  4503
Ignition Coil                 : With Dual Overhead Cam,    BWD E621
Ignition Coil                 : With Single Overhead Cam,  BWD E761
Tornado                     : Air Management System  k165
I gave the fram numbers cause you liked them so much. >:D
spyder0069 I didn't even know fram made an air filter for suzuki. I had the same problem at ww and no luck at pepboys so I got in the zone and found an stp filter, they had one I have two samurai. >:( I guess I will jut switch the filter to the one I am driving. ;)
You could look at online parts stores like I did for these numbers but maybe it slipped your mind. (http://www.partsamerica.com/default.aspx)
87 tintop, 88.5 conv
