3-4 speed auto
  • 19 Replies
  • 6257 Views
Offline azrocktrash
  • 121
Re: 3-4 speed auto
« Reply #15 on: October 28, 2004, 08:29:21 AM »
i have a queston.
if you replace the 462s with 512s and run 31s,how close to the stock ratio will you be?
    AZ
87 zuk,84 sj410  4 sale
come on,it' only sheetmetal!!
BODY DAMAGE IS ALWAYS AN OPTION
  ~Life begins,where the pavement ends~
Re: 3-4 speed auto
« Reply #16 on: October 28, 2004, 08:38:02 AM »
I could tell you, but you will like this
seeing it for yourself.
Go to my site
http://wildcatent.freeyellow.com/zookmods
and go to 4x4 calcs
There is a bunch of calculators to compute
all kinds of stuff related to 4 wheeling
Offline real_red_wagon
  • 226
  • Make It Hert!!!
Re: 3-4 speed auto
« Reply #17 on: October 31, 2004, 05:35:43 AM »
   See this is the debate I've been having ??? I work in a service dept. for a large GM dealership. Everything I read about the 3-speed trans. says 4.30, when I pulled mine out for the 5.12's out of a 5-speed and counted revolutions I came up with 4.30. Yet no one seems to know of this. I mean it makes sense as the 4-speed has an overdrive and the 3-speed doesn't right? ??? If you go to car-parts.com and ask for a third member for a 95 tracker it asks 4.30, 4.62, or 5.12 if you look it up for a sidekick it shows 16v auto 2dr with 4.30, 2dr 8v auto 4.62, 2dr manual 5.13, and 4dr 5.13 what gives? my truck is a 2dr 3-speed 16v that now has 5.12's in place of what I think were 4.30's how come no one agrees
At Lakeview Motorsports, were wasting your time already!
Offline jerryp58
  • 449
Re: 3-4 speed auto
« Reply #18 on: October 31, 2004, 06:29:58 AM »
I'm confused.  The specs you quote from car-parts.com say the 2dr 16v auto has 4.30s and that's what you think you pulled out of your Tracker so they do agree, or am I not reading that correctly  ???
I've read on other sites that my 2dr 8v auto (3-spd) has 4.62s, which matches your quote.
I think it's reasonable that a 5-spd manual and a 4-spd auto have the 5.12s cause they have the overdrive (and less than 1:1 trans ratio).
The 16v 2dr auto (which I assume is a 3-spd) is a little surprising.  I would have thought that with a little more HP (than the 8v) it could have run a lower gear than the 8v's 4.62.  Maybe they needed the higher gear (4.30) to help with MPG requirements  ???
So, back to the original post... do you have any specs on overall length of these transmissions, driveshafts, etc. or any other fitment info?
Jerry
Offline TN_Tracker
  • 1113
    • TN Tracker's Suzuki Space
Re: 3-4 speed auto
« Reply #19 on: October 31, 2004, 12:41:08 PM »
The 4.30 is for California Emissions Vehicles only or so I've read. ;)
