Can suspension be softened?
  • 17 Replies
  • 4920 Views
Re: Can suspension be softened?
« Reply #15 on: October 27, 2004, 04:42:27 AM »
With the side wall strength of the Swamper and the weight of your vehicle. I would think somewhere around 20 psi.
Offline explosivo
  • 3157
« Reply #16 on: October 27, 2004, 06:46:45 AM »
i run about 30psi in my swampers on road.  seems a little rough.  what would you guys(and gals ;)) say i should run?
stu
75psi ;D
I ran about 20 or so psi in my LTB's when they were on my sidekick.
« Last Edit: October 27, 2004, 06:47:25 AM by explosivo »
omghi2.us[/url]
Offline jagular7
  • 1026
  • Jagular7
« Reply #17 on: October 27, 2004, 03:46:57 PM »
My tires are rated D and max pressure is 65 psi for max 2335#s. I run these comfortably at 37 psi on the street. I started off at 45 psi when new and I'm still 'playing' with the pressure till I feel comfortable of the handling, control, and wear across the face of the tire. (I don't run a front sway bar.)
Lenexa, KS
