Zuwharrie 4-dr Action pics
  • 20 Replies
  • 6199 Views
0 Members and 32 Guests are viewing this topic.
Offline Mikerpm4x4
  • 2875
  • Redline... all the time!
    • www.rpm4x4.com
Re: Zuwharrie 4-dr Action pics
« Reply #15 on: October 22, 2004, 04:20:12 PM »
The problem I see hear is the short rear arm is lifting the front. Mine used to do that a lot.
Mike
BTW cool pics man, When you post pics you dont mess around!
Offline jagular7
  • 1026
  • Jagular7
« Reply #16 on: October 23, 2004, 05:25:26 AM »
It's the same symptom of the TJ's design. When lifting it greater than 4" or more, with the front axle hire than the rear axle, the rear axle will crawl underneath the vehicle rather than push it, as the rear axles does this, the front gets lighter. That's one of the biggest reasons the aftermarket went with a long arm suspension lift. Not only does this negate (not to 0, but much lesser) the rear axle walk effect, but the design also negates the effect of the track arm design.
Lenexa, KS
Offline nc_zuk
  • 406
  • Back in North Carolina
    • www.samurai4x.com
« Reply #17 on: October 25, 2004, 04:15:15 AM »
Mike
That pic is SOOOO deceiving. That was on a STEEP offcamber hilclimb. He was about 2 inches from rolling down the hill :o
www.Zuwharrie.com[/url]
Where the road ends........... Zuwharrie begins !!!
Offline Mikerpm4x4
  • 2875
    • www.rpm4x4.com
« Reply #18 on: October 25, 2004, 02:52:27 PM »
That will do it too! ;D I was just noticing how much angle was on the rear lower arm. Mine used to look like that... and then my front would look like that too!  :P ;D I just wanted to make sure he was aware of what a longer lower arm would do. Now that you mentioned it I went back and took a second look... I see it now.
Mike
Offline whitfield
  • 633
  • 4-dr Kick on 34's
« Reply #19 on: October 26, 2004, 01:12:19 AM »
Thanks,  Long arm rear is in the works, as well as another spring configuration, locked front, and Bumpers.
Offline lil_Truck
  • 1148
  • Eric Gardner
« Reply #20 on: October 26, 2004, 01:40:32 PM »
Nice Pictures.  Thanks.
32 MTR's Warn 8000i
