&*#^%$#*!^&$ fuel system
  • 26 Replies
  • 6788 Views
da_mtg_man
Re: &*#^%$#*!^&$ fuel system
« Reply #15 on: February 24, 2008, 02:51:30 PM »
Already tried it with the gas cap off and that wasn't it. I'm gonna drop the tank next and if that doesn't do it then I'm probably gonna drop the money on a weber. I'll add the line as well, Thanks for the tip. Any other suggestions out there?
Offline Armour
  • 360
« Reply #16 on: February 24, 2008, 08:02:56 PM »
just check the general condition of the lines. If a line or hose is cracked or has a pin hole could be sucking air and causing the problem.
« Reply #17 on: February 25, 2008, 02:23:57 AM »
I had a crack in the top of the fuel line coming out of the gas tank, didn't notice it until I dropped the tank.
Final issue ended being A) The cracked fuel line, B) Bad Fuel Pump, and C) Plugged Carb.  Now that all three are replaced, it seems to run fine.  :P
da_mtg_man
« Reply #18 on: February 26, 2008, 03:38:33 AM »
I found a carb that I'm thinking of getting 32/36 Model DGAV-33B1. The carb does not come with an adapter plate so is that something that I would have to pick up as well? If so, how much we talking?
Offline da_mtg_man
  • 58
« Reply #19 on: July 13, 2008, 06:23:45 AM »
Ok, I dropped the tank and there was no sock filter in there, I cleaned it out as good as I could and it didn't look to bad in there. I replaced the 3 smal rubber hoses coming from the fuel lines and the 2 hoses from the fuel pump down to the fuel lines. I put it back together and it seems to be running great however, I can't get anything up above the gas tank to get that freakin hose clamp on the big hose going into the top of the tank. Any suggestions. By the way, It's leaking gas because of it.
Some people are like Slinkies...
Not really good for anything,
But they still bring a smile to your face when
you push them down a flight of stairs.
« Reply #20 on: July 14, 2008, 09:55:02 AM »
I had to put that one on while the tank was dropped.  The easiest way is to put a jack under the tank and drop it until you can get access.
Offline beercheck
  • 1215
  • Go Cards!
    • trivia-nights.com
« Reply #21 on: July 14, 2008, 10:12:26 AM »
Any possibility of doing the old cut-an-access-hole-in-the-floor-above-it trick?
XL-7 front coils
1.5" rear coil spacers
Offline da_mtg_man
  • 58
« Reply #22 on: July 14, 2008, 10:49:21 AM »
Tried that, There is litteraly no play at all in that hose and no room to get a hand in between there.
Offline da_mtg_man
  • 58
« Reply #23 on: July 14, 2008, 10:50:34 AM »
I like your thinking. I am going to look into that when I get home. Thanks for the thinking outside of the box.
« Reply #24 on: July 15, 2008, 03:50:52 AM »
I disconnected the hoses at the other end.  But I have an SJ-410 so the plumbing might have been a bit different.  Beercheck's idea sounds good though.  Just make sure you have some metal to cover the hole back up with.  :)
Offline da_mtg_man
  • 58
« Reply #25 on: July 15, 2008, 06:31:46 PM »
update:
 I removed the back passenger tire and got a long pair of needle nose pliers along with a long screwdriver. I was able to get to the clamp and get it back on. I also found a small leak and was able to replace a hose clamp and tighten it down. I do have one more hose clamp that I need a little longer screwdriver to be able to tighten but the most important thing is that i have fixed the problem with it starving for gas.
Offline ack
  • 1659
  • Professional askhole
    • Ack's FAQ
« Reply #26 on: August 28, 2008, 02:54:52 PM »
What about the redneck carb clean. Maybe something is floating around and blocking up a passage. ??? ??? I would try that since it can't harm anything. ;)
-Adam ;D
Euh...what is that??
Here is a link that I found by using mexican as a search word at Ack's FAQ:
http://bbs.zuwharrie.com/content/topic,31520.0.html
I hope that this helps!
Ack
