92 Tin Top, Can it tow?
  • 25 Replies
  • 6660 Views
Offline Carnage
  • 2453
Re: 92 Tin Top, Can it tow?
« Reply #15 on: March 04, 2008, 01:49:54 AM »
The picture of the Tracker and camper that GEN-ERIX posted above is my rig.  The camper only weighs about 800 lbs and we carry about 150 lbs of gear in it.  It tows very well in the flatlands, and struggles a bit if there is much of an upgrade.  I would not consider towing anything heavier than this for any distance.
yeah, i think that setup is awesome
« Reply #16 on: March 05, 2008, 05:57:31 PM »
I have a '88 tin top and I had to get my motorcycle down to the dealer in Olympia. Renting a van from U-haul for this was more than I wanted to spend again so I set the Samurai up for a trailer and rented one set up for motorcycles. I wish I knew how much it weighed but it seemed pretty stout. My bike weighs about 400lbs. wet. I was real worried about how sammy would handle it but all was well after I calmed down.
Offline Indy
  • 18
« Reply #17 on: March 07, 2008, 08:17:41 PM »
I wouldn't do it regularly or for very long distances, but if it's a manual and you drive very carefully, it can be done...
People play russian roulette and don't die.  Until that last game anyways.  No matter how careful you plan on being you have to assume that at some point something horrible is going to happen and you're going to kill someone if you start out with what you already know to be unsafe.  Do the tow 3 times and no incident doesn't make up for the 4th when the little kid steps out in front of you and you run her down.  As has been said above, tow ratings aren't set by what the vehicle can potentially move.  It's what it can control and stop.  If it were based on forward movement even the sammi would have the same rating as a 3/4 ton truck.
The MAX towing capacity according to edmonds is 1000lbs.  MY ATV HAS A HIGHER RATING.  Obviously not a highway tow, but the rating is there.
Offline Digger
  • 1991
  • 1996 Suzuki X-90 4X4
« Reply #18 on: March 07, 2008, 11:59:51 PM »
Like I said, I wouldn't do it regularly or for long distances...
At the time, Silver was the only thing I had that could tow the Goblin home and the sammy to the shop...
« Reply #19 on: March 08, 2008, 07:09:43 AM »
Like I said before.. Suzuki state 3197lbs
Offline jzap
  • 515
  • How difficult can it be?
« Reply #20 on: March 08, 2008, 09:49:27 AM »
Rhinoman is in Europe, where tow ratings are not determined by the fear of LAWYERS...
Over here any fool can install a hitch, hook up a trailer to it and head out down the road (at least in Ohio).  My hitch and wiring for my camper are all off the shelf and home installed.
Rhinoman, aren't towing rigs there more stringently controlled there than they are here?
Jim Z.
66 Apache camper
phloop
« Reply #21 on: March 08, 2008, 01:29:54 PM »
Any Suzuki is a towed rig not a tow rig. The safest thing's you can tow are riding lawn mower's, bikes and the like on one of those light weight Home Depot fold up trailers.
If you want too tow, get something meant to tow with. I really don't care if you fold up your rig but when you endanger innocent people that is a different subject.
Offline jzap
  • 515
« Reply #22 on: March 08, 2008, 09:17:08 PM »
I know what you mean.  I was riding in a friend's J**p towing a trailer with a J**p body tub in it.  Not all that much weight, but we started down a hill, and the trailer tried to pass us.  He almost lost it.
So, I spent over a year looking for a camper that was within the tow rating of the Tracker.  We have put hundreds of miles on it without incident.  We have not had any problems with sway or instability, even with some really stiff crosswinds.
The Tracker can tow safely, but not the kinds of loads originally proposed in this thread.
Jim Z.
66 Apache camper
« Reply #23 on: March 10, 2008, 05:55:46 AM »
We have lawyers over here as well but its EU Type Approval that really counts. Suzuki wouldn't be able to claim 3197lbs without proving it was safe.
The law here in the UK is that anything more than 750kgs must be braked. The laws get pretty complicated but as a general rule the max. legal towing weight is about 2/3 the weight of the vehicle. There aren't any regs on towing vehicles other than weights. Tow hitches must be type approved for the vehicle and carry an identification plate, they can be DIY installed. The law on towing changed a few years ago such that newly qualified drivers must take a further test to be allowed to tow anything.
How many of those people saying it isn't safe have actually towed any kind of weight with a Track/Kick. It seems that those of us that have have a different opinion to those that are just speculating. I should also point out that I did my heavy towing with a stock motor on road tyres. I think you'd have to be much more wary if you're lifted.
phloop
« Reply #24 on: March 10, 2008, 08:45:42 PM »
Rhinoman, I think I can post my opinion as I have done a little towing with a sami before. Most with a small utility trailer that is in the weight range of the rig. I have yarded my car trailer around the house before and that thing will take control of the Sami in no time.
And if I want to tow something I will use the proper rig, which in my case is a DRW Dodge 3500.
Offline Cuthulu
  • 384
« Reply #25 on: March 10, 2008, 08:54:29 PM »
My shop manual and my owners manual for my 94' tracker clearly state 1000Lbs max.  There is just no way to have control over weight that almost matchs if not exceeds your own unless it is built for towing.  Using the wrong tool in a pinch is one thing but this is a danger to others who had no sayso in your decision.
« Last Edit: March 10, 2008, 09:02:05 PM by Cuthulu »
