Still hard starting.
  • 23 Replies
  • 5168 Views
Offline Speedracer7c
  • 2210
Re: Still hard starting.
« Reply #15 on: October 17, 2004, 11:26:15 PM »
How do i check the key in the crank just pull the cog off?
« Reply #16 on: October 17, 2004, 11:56:10 PM »
   If it starts fine once its warmed up, could be the ECT sensor??
« Reply #17 on: October 18, 2004, 06:05:47 AM »
the distributer on the 16 valve turns the opposite way from the eight valve 1.6 engine, so it could still be a broken key on the crank  :-/
  • 2210
« Reply #18 on: October 18, 2004, 06:50:08 AM »
But if it was a key on the crank being bad, wouldn't it go more and more out of time? I have driven it like this for about 4 months now. I hope it could just be a sensor.
« Reply #19 on: October 18, 2004, 01:20:53 PM »
Could be the bolt tightened
and now it can't turn anymore,
could be a piece of the key is wedged
between the cog and crank
I took apart a jetski that the nut had
come off the flywheel, hit the case which
screwed it back on and it kept running,
then it came off again, totally destroyed
the key and the crank slot, wierd things
happen, but if you check it all out and
nothings wrong, then I would be puzzled,
because somthing caused the timing to
change, I'm just suggesting things that
could have happened
  • 2210
« Reply #20 on: October 18, 2004, 01:35:24 PM »
Thanks. I'm just praying thats not it. I don't have time to put my car out of comissino to check that.
« Reply #21 on: October 18, 2004, 01:44:35 PM »
It's not much more than the resetting
of the belt that you allready did
And think of it as good practice to
keep your skills sharp
  • 2210
« Reply #22 on: October 18, 2004, 02:42:45 PM »
So what do I have to do in order to check the key way?
« Reply #23 on: October 18, 2004, 03:58:06 PM »
Just get it all the way down to the
timing belt, remove the belt and the
bolt in the end of the crank, the cog
should pull off without too much force,
if it is stuck on, there might be a bad
key, I would reccomend using an impact
to remove the bolt, they can be a PITA
otherwise, espesially with an Auto Trans,
can't put it in gear to keep the engine
from rotating.
Now inspect the keyway, key and cog,
if the engine is TDC (Top Dead Center)
the keyway should be up, the notch in
the Cam Sprocket should be down, and
the rotor in the distributor should be pointing
to where #1 (front) Spark Plug wire is at,
if it is pointing at the opposite side, you are
180 out, but the notch in the cam would be
pointing to another spot too I think.
You might find some missing teeth on the
belt, inspect it closley, and cracks or checking
of the backing (smooth side) you should
replace the belt.
Hope this helps
