I have a pink tracker and im a guy :(
  • 100 Replies
  • 23007 Views
Offline Cwkick
  • 888
Re: I have a pink tracker and im a guy :(
« Reply #30 on: October 06, 2004, 08:54:04 AM »
azrocktrash,
A friend of your's had a Calmini lift with alignment problems?
The OME lift does nothing to address alignment problems.  At least Calmini makes the control arms longer to take care of camber.
May I ask what type of problems your friend was having?
Cwkick
Offline explosivo
  • 3157
« Reply #31 on: October 06, 2004, 09:33:14 AM »
azrocktrash,
Cwkick
It's possible that he had the same problem with the Calmini lift that ProjectTwin did, in that you have to do an alignment yourself if you want to drive it to the alignment shop... :-/
Calmini lifts would seem to have less alignment issues than RRO lifts, since the ones RRO sells use spacers that screw up the camber...
omghi2.us[/url]
Offline wolf66
  • 193
« Reply #32 on: October 06, 2004, 09:46:14 AM »
1st call it "a strange shade of purple"
2nd body lifts not so bad on cornering since all the heavy stuff like motor, tranny and axles didn't move up, only the light stuff like the body work did.
'96 Suzuki X90-4" lift-snorkle-30x9.5's on 8x15 wheels-5.12 gears-winch-added rear seat-DT header-PioneerMP3-CB-GPS-roof rack-rear mounted full size spare
spinaltap
« Reply #33 on: October 06, 2004, 09:48:32 AM »
RRO uses springs and spacers...and yes your camber will be out unless you use camber bolts to correct. My camber bolts are set to max offset and the camber is bang on spec. I believe that the Calmini kit is the better system in regards to toughness and flex...possibly ride...But in my case I think the RRO lift will work out the best for me. If I was to build a rig that was more oriented to off-road I would definitely go with the Calmini 3+3 with many of the Hagen mods :)
Offline mytrackerispink
  • 23
  • My Tracker Is Pink
« Reply #34 on: October 06, 2004, 10:18:45 AM »
i've been calling it magenta.... rasberry's a little beter too...  but yeah i thinik now im just gonna get the 2'' suspension and 3'' body lifts once i get enough cash.  thanks for the tips.  and im glad to see theres another guy who had a pink tracker!
Offline Maiden Hell
  • 1650
  • MAIDEN HELL!
    • My Space
« Reply #35 on: October 06, 2004, 10:27:52 AM »
Pulp Fiction is one of the best movies of all time.
Dude, just get it repainted.  These days it don't cost all that much.
Offline azrocktrash
  • 121
« Reply #36 on: October 06, 2004, 12:08:46 PM »
azrocktrash,
Cwkick
don't know other than he said, "it would not aline,even the F*&%#n alignment shop could not get it to line up."
        AZ
87 zuk,84 sj410  4 sale
come on,it' only sheetmetal!!
BODY DAMAGE IS ALWAYS AN OPTION
  ~Life begins,where the pavement ends~
  • 23
« Reply #37 on: October 06, 2004, 12:16:27 PM »
i know painting its cheaper but i'd like to put a couple mods into it.
Offline Speedracer7c
  • 2210
« Reply #38 on: October 06, 2004, 01:28:34 PM »
My alignment was waaaaaaaaaay out. I did an alignment, and they drove it in the shop put it on the rack and said they coudln't do any better than it was. So I guess the old tape measure thing works lol
Offline Cwkick
  • 888
« Reply #39 on: October 06, 2004, 01:29:55 PM »
az,
sorry your friend had a bad time with his lift.  I'm glad he likes his OME lift.
mytrackerispink,
build it how you want it and have fun!
I think GM calls the color magenta.  ;D
Cwkick
  • 23
« Reply #40 on: October 06, 2004, 01:31:46 PM »
technicaly its mystic magenta metalic.... somehow pink sounds beter....
  • 2210
« Reply #41 on: October 06, 2004, 01:33:39 PM »
Ah...who cares! It kicks ass either way.
  • 2210
« Reply #42 on: October 06, 2004, 01:34:56 PM »
Here is a picture of my tracker before we did an alignment, You can see how bad it was. That was with the wheel straight and both wheels looked like that.....
mperry
« Reply #43 on: October 06, 2004, 01:38:42 PM »
its a 93, 4x4, automatic... and its pink...
PICTURE: http://www.imagedump.com/index.cgi?pick=get&tp=132241
When you said pink, I thought you meant Barbie truck pink. (Isn't that color called Cranberry?)
  • 23
« Reply #44 on: October 06, 2004, 01:44:34 PM »
well the first thing i hear when people see it is wow its pink...  and one time im driving though town and stoped at a cross walk and this 4 year old kids like hey mom look a pink car.  soooo...
