Richmond gears?
  • 21 Replies
  • 5596 Views
Offline tipover
  • 422
Re: Richmond gears?
« Reply #15 on: May 31, 2008, 11:13:25 AM »
takes balls to admit wrong... you're a good guy.
RV Dingy-2003 2 door tracker
RV- 31' Monaco Mckenzie
Offline beercheck
  • 1215
  • Go Cards!
    • trivia-nights.com
Re: Richmond gears?
« Reply #16 on: June 01, 2008, 07:49:09 PM »
As CJ said, a 4.625 or a 4.30 will work well enough.
Now you're talkin'.
Sorry beercheck for going against you when I was totally wrong.
No worries of any kind.
XL-7 front coils
1.5" rear coil spacers
Offline lil_Truck
  • 1148
  • Eric Gardner
Re: Richmond gears?
« Reply #17 on: June 03, 2008, 12:03:52 PM »
I have the 5.83's and a 4.25 trasfer case.
If I had it to do over I'd go with the double tranfer case with a sami T case.  The sami has the gear reduction for highway speeds and the doubled up T cases would give you a Hi - Mid - Low range.
I added it up once and came out to about 1/2 the price of the way I went.
32 MTR's Warn 8000i
Offline lostsamurai
  • 433
  • LOSTSAMURAI
Re: Richmond gears?
« Reply #18 on: June 03, 2008, 06:11:27 PM »
i use a custom adapter to eliminate the "married trackick t case" and run a samurai like intermediate shaft to my samurai t case i run this on my samurai with an automatic sidekick tranny and 1.6 16 valve engine with 6.5:1 t case gears. im currantly doing this exact setup on one of my 2 door trackers
Offline tipover
  • 422
Re: Richmond gears?
« Reply #19 on: June 03, 2008, 08:39:46 PM »
yea, i got many sammy t-cases around, but I drive my kick every day to work and I flat tow it behind my motor home.  I got a sammy for the hard stuff and want to keep the kick high speed worthy.  So the offset rear is a problem for me.  I just wish i could find a set of R&Ps for it and a IFS lift to keep it sane...
Re: Richmond gears?
« Reply #20 on: June 04, 2008, 06:56:03 AM »
Now you're talkin'.
Thanks Beercheck. Also thanks to Tipover for the help on the PM.
Offline lostsamurai
  • 433
  • LOSTSAMURAI
Re: Richmond gears?
« Reply #21 on: June 04, 2008, 11:53:44 AM »
i use to drive mt sammi to work every day at 75 mph pass drop t case and centerd toyota rear end no vibes, just use a cv type driveline
