Winch Wiring question
  • 16 Replies
  • 4085 Views
Re: Winch Wiring question
« Reply #15 on: October 31, 2008, 08:28:06 AM »
Having an emergency shut off on your winch is a good idea.  I almost burned my winch up when a solenoid locked open when pulling up the hill and had to pull the battery.  If it was me I would put the switch under the hood and just leave the winch on full time.  I have never had my winch run off on it's own on me and it saves time when winching.   Roadless Gear has a winch control setup you can easily wire into your winch for in dash control you might light to check out over here.
When you wire it, I would go to the top post on the battery instead of the side.  The side posts are usually connected via a copper strip to the top post.  If it is a cheap battery or your connection is a little loose you will generate to much heat and melt the side post off.
For the winch, I would reach up with a welder after everything is bolted down and put a tack on a bolt or two.  That will stop interested fingers from walking off with it unless they are carrying around a grinder in their back pocket.
Offline SNJSamurai
  • 386
« Reply #16 on: October 31, 2008, 11:00:12 PM »
you guys have great points. so def going to put some type of emergency cut off switch.
and good ideal about the tack welds
ill let you guys know what i ended up doing later
Bob
