What can be done with these?
  • 21 Replies
  • 5624 Views
Re: What can be done with these?
« Reply #15 on: December 27, 2008, 05:52:50 PM »
I've found some information on the diffs (4.62 gears). Is this the gearing in 5-speed and auto trans? Which 5.125 gears (from Gen 1) do I need (front / rear / does it matter?)? Are the stock tires on Gen2 27" as well? If so, according to my calculations, 5.125 will correct for 30" tires perfectly - is that correct? It looks like Gen 2 is 16" rim - is that so? Are they still 5 on 5.5" bolt pattern? Sorry for all the questions, I really am trying to dig and search, but there's a real lack in specifics in some of the chatter in other threads  :'(
« Reply #16 on: December 27, 2008, 06:10:37 PM »
Oh, and I have an extra OME lift kit for Gen 1 - does anyone know if it'll fit?
« Reply #17 on: December 27, 2008, 08:36:34 PM »
My 2001 Tracker(GV) has 15" rims that are 5 on 5.5", but the Suzuki version has the 16" rims. That's from what I've seen around, not sure all years are the same.
2001 4 door Tracker. 2.5 V6 4x4
235/75/15 Firestone Destination A/T's
Jeff's 2" spacer lift
Offline IanL
  • 466
« Reply #18 on: December 28, 2008, 02:14:27 AM »
Suzukis have larger front brakes and need the 16" wheels to clear them.  The bolt pattern is the same.
For gear ratios see http://bbs.zuwharrie.com/content/topic,18763.0.html
If you change final drive gears, you must change front AND back.  I believe it does matter about front to front, etc.
« Reply #19 on: December 29, 2008, 12:00:00 AM »
I should have been more specific... I know I'd be changing the front & rear in the Gen 2 - I'm wondering if I need the front or rear from the donor vehicle (For example, in Samurais you can only use the diff gears from the front).
Offline olija
  • 770
    • Check out my cardomain
« Reply #20 on: December 29, 2008, 04:37:17 PM »
Not true! I have put a 15x7 Jeep CJ rims on my 01 Vitara and it cleared the caliper and rotor just fine! The rims have 3.75" backspacing, just so you know. I think the style of the rim really matters in whether it will clear or not.
Offline IanL
  • 466
« Reply #21 on: December 31, 2008, 01:30:45 AM »
Ok, I should have said ".. and cannot accept the stock 15" rims."
