Which Winch ???? For a tracker 4 door
  • 21 Replies
  • 6768 Views
Re: Which Winch ???? For a tracker 4 door
« Reply #15 on: January 13, 2009, 11:03:04 AM »
I've not seen them in action, but the guys running the cheap HF winches swear by them. A small lightweight winch is fine. I would even argue a 2000 lb winch with a snatch block would be fine for most applications. Unless you're in mud, where suction / vacuum is a problem, you'll only have a few hundred lbs of resistance on the line anyway.
That said, I use a Warn 9000 'cause I wheel with heavier rigs sometimes... and do like me some mud. Those big 40" tires under full sized trucks can really suck down deep sometimes.
« Reply #16 on: January 13, 2009, 11:33:20 AM »
The only problem with rope is you need to clean it out if your using it in mud.  Otherwise it gets in and starts to destroy the fibers.  Cable is a lot more low maintenance then the rope for a trail only rig.  :)
Offline dingus
  • 107
« Reply #17 on: January 13, 2009, 04:07:39 PM »
Hi Jeremiah this was my Thinking to!
By HF winches what is a HF winch?
I found a Supper winch its a 3000 Lb one that i think will do with cable.
I cant see Mud being the thing i get stuck in around here its gona be Deep snow.
I like the 3000 Lb one.
Thing is the 8000 Lb one is only $100 More eh. ??? so whats a guy to do.
I like the Light weight Smaller Winchs.
 Cause im keeping my Rig light weight  with just 29 Inch tires so i dont start getting like 20 MPG.
i dont want to loose on Gas milage to much eh.
Offline skitime
  • 302
« Reply #18 on: January 13, 2009, 06:10:44 PM »
I just weighed my new M8000 Warn winch I am putting on my new rear bumper. It is setting here without the cable and it weighs 34 lbs.  The 100' steel cable weighs 16 lbs. An Amsteel rope might weigh 4 lbs.  Do what you want with that info but a winch is not that heavy especially without the steel cable.
Offline dingus
  • 107
« Reply #19 on: January 13, 2009, 08:36:35 PM »
Warn M 8000 is only 34 Lbs thats not bad at all.
Amsteel is the way to go eh!
Its hard to Decide cause i just found a 6000Lb Vortex winch for like $200
Im gona buy one and give it a try.
At worse i can use it to load my Inflatable boat on my Motorhome roof  :laugh:
Offline lil_Truck
  • 1148
  • Eric Gardner
« Reply #20 on: January 14, 2009, 01:49:27 PM »
When I had a steal cable, no matter how careful I was it seemed to bird cage and kink one me.  It was hard to work with.
The Amsteal rope is very soft and has no stiffness to it at all.
I live in Michigan and if I get stuck its in mud.  Never had a problem with it.
32 MTR's Warn 8000i
« Reply #21 on: January 15, 2009, 07:00:10 PM »
HF = Harbor Freight
Snow can be a problem too if it's "building up" in front of the vehicle / drivetrain components creating a lot of resistance. A 30 lb difference between winches isn't going to kill your MPG.
