Flywheel
  • 19 Replies
  • 6151 Views
Re: Flywheel
« Reply #15 on: November 11, 2005, 04:22:45 PM »
As far as flywheel weight, a heavier flywheel can make offroad
driving a little easier with an engine that doesn't stall at easily
while you are slipping the clutch on hills, it's the inertia that keeps
engine from stalling as easy.
I did consider fitting a Samurai flywheel to get a bit more acceleration but thats exactly why I didn't.
Re: Flywheel
« Reply #16 on: November 11, 2005, 06:03:19 PM »
ya that one is aluminum with a steel insert, I just put it up there cause it looked cool  8) hey wild you could use that for your flex plate.  ;D
Offline BV1
  • 58
  • X-90 fan :)
Re: Flywheel
« Reply #17 on: March 27, 2006, 01:29:20 PM »
Ok... so the verdict is, I can fit any flywheel from the 1.3/1.6 8v to the 1.6 16v. Correct? Will the clutch still work on the 16V or will I need a spacer?
What about the G13B 1.3 SOHV 16V flywheel? Is it the same as the 8v engine?
Thanks,
-Steve
Offline Yoak
  • 577
Re: Flywheel
« Reply #18 on: March 27, 2006, 10:12:54 PM »
Ive read and been told by several people that the 8V Clutch will work w/o any issues on the 16v
Offline urbanwheeler
  • 696
Re: Flywheel
« Reply #19 on: March 27, 2006, 10:47:09 PM »
I have a spare 8v clutch and flywheel out of my 1990 geo tracker. The flywheel on the tracker is much thicker and heavier than the one on the samurai. I also can let out the clutch at idle in first gear, and it wont stall as easy as most cars due to the low first gear and heavy flywheel
