sas on sunrunner 2x4
  • 24 Replies
  • 7920 Views
Offline matt4x4
  • 26
Re: sas on sunrunner 2x4
« Reply #15 on: February 16, 2009, 04:49:53 AM »
Is that with YJ front or rear leaf springs? Also with YJ leaf springs is it spring under or spring over, I don't want to be too high. Im only running 31s this year and going to 33s next year.
« Reply #16 on: February 16, 2009, 08:31:04 AM »
I do NOT recommend tossing away your coils for leaf springs. Coils are SOOOOOO much better. Still not sure why anyone would SAS to go to 31" tires anyway  ??? 33"+ makes sense, but you can stuff 31" tires under the IFS setup with about $200 worth of parts.
Offline matt4x4
  • 26
« Reply #17 on: February 16, 2009, 09:12:34 AM »
I Have access to both pcs (ifs and sammy axle) , I wanted to got with the solid axle because I want to put a locker in the front. I know you can swap in a GV steel housing put then it's the cv joints you have to worry about. Am I on the wrong track?
« Reply #18 on: February 16, 2009, 11:20:04 AM »
Well, with a locker you may be on the right track. But, there's some other options out there you might want to consider before diving into the SAS...
You should be okay with 31" tiers still & the Mike Hagen widening mod makes it EASY to swap CV's if you need to (cheap, light & easy to carry trail spare). You can also add a strap around the rear "out put" of the front diff which does a LOT to strengthen it (most the carrier failures are from diff movement under torque). There's also ways of using Toyota CV's if you're uber-worried about it. And, you can use the Samurai front axle (shortened axles) as your steel carrier. Or - a Toyota steel front: http://www.pirate4x4.com/forum/showthread.php?t=318480
I personally LOVE coils, and REALLY LOVE my IFS. But, I do a lot of fire roads, mud & dessert (read:high speed style) wheeling where IFS is king. Coils are king in every situation but towing heavy loads (so, they're always good in Suzukis). If nothing else, you may want to consider keeping coils, and going SAS. LOADS of people have done coil & link, so just copy their builds. You can also re-use (sleve & lengthen) a lot of the rear-suspension bits if you stay coil. I believe it's Ford Ranger coils rated around 200# that are the cheapest way to go if you want lift.... or you can just do the coil-spacer thing 'till you can afford new (longer-travel) coils.
Offline 91zukisas
  • 140
« Reply #19 on: February 18, 2009, 07:04:13 PM »
I used yj springs front and rear. Spring under axle 31" tires would be fine. Spring over 31" tires are to small. I get plenty of flex out of my leafs and the ride is great. I went with leafs over coils just because it was easier and cheaper. The whole coils vs leafspring thing could pretty much be a ongoing battle. I like them both.
91 2door Sidekick yota Axels  SAS Kit, header and custom intake, etc
04 Kia Sorrento, Limited slip, 31X10.50 2" lift
89 Sammy Tintop-new project :D
95 TSI, EVO 3 16g turbo swap, front mount, 20lbs boost
« Reply #20 on: February 19, 2009, 03:07:11 AM »
Leafs are "easier" to install in that they're easier to design. Forward / rearward hold is handled by the leafs, and they also somewhat take care of lateral motion (often not requiring panhard bars in light weight Suzukis). So, often times one can get away with no links at all.They're also more plentiful, so sourcing leafs is usually easier. Leafs can handle loads better, which is why they're almost always in the rear of trucks (limiting factor on weight for Suzukis is usually engine power, so this is a non-issue for us).
Coils ride better (WAY superior - especially on-road or at speed), and they don't stick out past the wheels, so approach / departure angles are much better (especially if you stretch out the wheel base a bit). Links will need to be engineered for forward / rearward and lateral motion without causing binding - meaning more thought needs to be put into the design.
Pick your poison...
Offline matt4x4
  • 26
« Reply #21 on: February 19, 2009, 09:36:47 AM »
I'll be honest, I love my IFS !!! I do mostly mud , snow and rocks. My problem is that I really want to lock the front diff and from what I have read the aluminum housing will not take the stress. I'm not a master fabricator so I'm looking for the easiest bolt on way to lock the front. I will happily swap over all my IFS from my current kick into the sunrunner, but how do I lock it without worring everytime I go out and beat it? ???I thank you all for your continued replies.
« Reply #22 on: February 19, 2009, 09:45:05 AM »
The best way is to create a couple metal straps that "wrap" around (more like sandwich) the rear part of the diff where the drive shaft comes in. I've seen how-to articles on this, but I can't find them for the life of me. What it does is stop a lot of the twisting (basically axle wrap) that goes on because of Suzuki's poor design. This GREATLY strengthens the front diff. The other thing is to swap out to a steel diff (Grand Vitara, custom build Samurai, or Toyota). I can say that a lot of people survive with 31" tires without a problem. Some people break. I'm sure it has to do with luck & driving style.
If it were me, I'd just do the wrap / sandwich thing, lock it, and wheel it. If the front broke, I'd replace it with a steel housing... otherwise I'd just keep wheeling it.
Offline matt4x4
  • 26
« Reply #23 on: February 19, 2009, 09:56:24 AM »
[/quote]
See thats my problem, I've been so caught up in trying to modify that I missed the whole winter season. :-[ I think I might look into the GV front and just lock it up, then beat it till it breaks ;D
Jeremiah , whats your front end set up?
« Reply #24 on: February 19, 2009, 12:30:40 PM »
Other than OME lift, and 29" Dakota M/T tires, I'm 100% stock. I should do something to strengthen the front diff, but I've been too lazy, and I think I'm okay with the smaller tires for a while. Don't hear about many people breaking the housing with 29"ers even with lockers.
