Anyone know about this HF tube bender?
  • 21 Replies
  • 5780 Views
Re: Anyone know about this HF tube bender?
« Reply #15 on: February 24, 2009, 09:56:08 AM »
Pipe = measured by outside diameter
Tube = measured by inside diameter
That's why I thought the $100 HF pipe bender wouldn't bend tube. Then again, I'm pretty sure (trying to remember here) they were trying larger 2" tube. Maybe the smaller 1 1/4 tube will bend okay in the 1 1/4 pipe die? Anyone else have experience with tube in the pipe bender? What size?
I'm likely going to be making a pipe cage (unless enough people chime in that they did tube successfully) with that HF bender. I would LOVE to use a tube bender (for those that don't know, it sort of stretches & forms the tube over the die, instead of just "pushing" the bend into it), but it's just too much $$$.
Pipe cage:
* Cheap
* WILL have kinks, so the bends can't be considered structural. Design a properly triangulated cage (pretend all bends are held on by bubble gum, and triangulate / gusset accordingly), or you'll be sorry
* Not as strong as tube (but, with a 40,000 psi yield, it's more than enough for a light weight Suzuki IMHO.)
* Heavier (raises center of gravity) by a bit. I think .1 - .2 lbs per foot?
Tube cage:
* More $$$ (the bender alone will pay for the bender & material on the pipe setup)
* Will still need triangulation, but bends will provide some structure, and therefore require less triangulation
* Lighter (lower center of gravity)
I'm not trying to turn this into another pipe vs tube debate, but thought those things were worth mentioning.
Offline 96Kicker
  • 1043
  • http://www.zukiworld.com/forum/gallery/3710_25_10_
    • www.myspace.com
« Reply #16 on: February 24, 2009, 10:03:26 AM »
Inside or outside, who gives a crap as long as if it is strong and built right.  Although I did not know the difference between tube/pipe/measurements/bender. Thanks.
<a href="http://s220.photobucket.com/albums/dd126/fletcher9160/?action=view&current=Zuktahgreenblur.jpg" target="_blank"><img src="http://i220.photobucket.com/albums/dd126/fletcher9160/Zuktahgreenblur.jpg" border="0" alt="Zuktah club sticker"></a>TJ
#801-554-3281
96 kick 4 door with custom 3 inch susp lift and pre runner front bumper,2 inch bod
Offline Swansen
  • 64
« Reply #17 on: February 24, 2009, 02:05:49 PM »
i had this really useless post all made up.. but it was about this tube bender i couldn't remember the name of that was featured on Trucks! but i found this one. http://www.medfordtools.com/mb3.html same thing only different.
Offline 91zukisas
  • 140
« Reply #18 on: February 24, 2009, 03:55:26 PM »
Yeah that one is nice but is cost allot more
91 2door Sidekick yota Axels  SAS Kit, header and custom intake, etc
04 Kia Sorrento, Limited slip, 31X10.50 2" lift
89 Sammy Tintop-new project :D
95 TSI, EVO 3 16g turbo swap, front mount, 20lbs boost
Offline Amilla
  • 1076
« Reply #19 on: February 24, 2009, 04:16:03 PM »
I built my front bumper with the HF hydraulic bender. 1-1/4  3/16 steel tube  bent like a charm.
This is the bender I used
http://www.harborfreight.com/cpi/ctaf/displayitem.taf?Itemnumber=32888
Here is a pic
Me and my buddies call that bender the harbor freight tuber krimper.
It did work fine for jobs that needed a minimal amount of bending, but places where we need tighter bends repetitively...it was not up for the job.
There's a full thread on pirate4x4 about improving there design of that model.
It looks like it did a killer job on your bumper thou!  Nice work.
Amilla
Offline RazBarlow
  • 156
  • It's Barney !
« Reply #20 on: February 24, 2009, 04:23:24 PM »
Do you happen to know off the top of your head what the threat was called on Pirate 4X4 ?
Thanks,
raz
« Reply #21 on: February 28, 2009, 10:54:54 AM »
If I remember correctly, they either used a tube die, or... bent up another larger tube / pipe that was the correct inside diameter to convert the pipe die to a tube die.
