Anyone ever mount a receiver to this ?
  • 24 Replies
  • 5761 Views
Re: Anyone ever mount a receiver to this ?
« Reply #15 on: March 02, 2009, 01:19:59 PM »
So if it is strong enough for a car to slam into the back of it and keep your rig from blowing up like a ford pinto it's not Strong enough to pull a hundred pound trailer I guess!
Offline beercheck
  • 1215
  • Go Cards!
    • trivia-nights.com
« Reply #16 on: March 02, 2009, 01:23:44 PM »
You should take a minute and pull it off just for S&Gs.  You'll be shocked how light it is.  Shocked, I tellya.
XL-7 front coils
1.5" rear coil spacers
« Reply #17 on: March 02, 2009, 01:30:28 PM »
You're talking about 2 totally different functions, and therefore two totally different designs. The bumper is designed to survive a 5 MPH impact (yes, that's it - that's all they're required to do per DOT standards), it's not designed to save the fuel tank. The boxed frame is designed for that. There's also a difference between impact, and towing (pulling, twisting, and lateral movements).
There's bolt holes on the bottom of the bumper for bolt-on tow packages. Use them! They're specifically designed for what you want to do. Why all this effort on designing a work-around?
Offline Bandit02
  • 171
« Reply #18 on: March 03, 2009, 07:49:38 PM »
Sounds like you already have your mind made up... SO why did you ask us for advice? Everyone here has given you thier honest and experienced knowledge on the subject, but You've got a reason why we are all wrong... No offense. I hope it works out for you, I did the same things and pulled a VERY SMALL trailer, and it didn't hold up; maybe your luck will be different   :-\
95 tracker on 33s
« Reply #19 on: March 03, 2009, 09:52:19 PM »
I was not the one asking the big Q but I did build one for a cheap friend of mine and he has hundred's of miles on it, mine that I built for me was made from a f350 one ton hitch class III with extra grade ten bolts torqued to fifty pounds each with large washers on the frame, so I know where you are coming from but like I said we have little to no rust here.
Offline Bandit02
  • 171
« Reply #20 on: March 04, 2009, 05:41:44 AM »
Oops   :-[ .. lol, sorry about that. Guess I should pay better attention next time, huh? haha
95 tracker on 33s
Offline TopHeavy96
  • 488
« Reply #21 on: March 04, 2009, 05:30:48 PM »
There are threaded holes on the bottom of the frame for a hitch, I know cause the hitch was the first thing I ripped off for more ground clearance/departure angle.
« Reply #22 on: March 04, 2009, 06:22:17 PM »
I hear an echo...
Offline Uncivilized
  • 1469
    • Car Domain
« Reply #23 on: March 08, 2009, 09:41:34 AM »
The tank saver is not for a rear end collision, but more of a bump protector for those people that like to reverse into garbage cans and "no parking" signs.
It is very flimsy, most of these factory add on's are... I actually cut off my gas tank skid plate yesterday with a set of channel lock crimpers  ???
xkmail
« Reply #24 on: March 09, 2009, 08:02:09 AM »
I went to uhaul and got the hhitch.
When you take out the 4 bolts that hold this to the frame, the uhaul hitch bolts right up.
You can then run your wiring right under the bumper and into the left tailight housing.
It was about $120 for the hitch and is very solid.
kb
