New 2003 Tracker here, got some questions.....
  • 18 Replies
  • 5981 Views
Re: New 2003 Tracker here, got some questions.....
« Reply #15 on: May 13, 2009, 06:41:30 PM »
Ok so its the central hub, not the brakes that don't fit.  Has anybody managed to get cragars or aftermarket wheels on their tracker?
2003 chevy tracker (2.0L-auto-2 door-soft top)
MODS SO FAR....
-235/75/15 w/cragar soft 8's
-painted grill/graphics removed
-bull bar + off road lights
-Jeff's 2" spacer lift w/new rear shocks
-flowtech muffler
-Pacer Fender Flares
Offline beercheck
  • 1215
  • Go Cards!
    • trivia-nights.com
« Reply #16 on: May 14, 2009, 06:44:21 AM »
Hmmm.  A list of aftermarket wheels that are proven to fit over small and/or big-braked Trackers/Vits.  I don't think that's been done before.
Sounds like a job for Jeremiah.
XL-7 front coils
1.5" rear coil spacers
« Reply #17 on: May 14, 2009, 12:53:58 PM »
It seems like the more I read, the more confused I get.  From what I gather so far, the trackers are similar to the grand vitara's, but don't have the big brake hardware.  Can anybody say for sure if normal aftermarket 15-16 inch wheels (like the black 15" cragar steel wheels I want) will clear the brake hardware on a stock 03 tracker?
-Thanks
-dan
MODS SO FAR....
-flowtech muffler
Offline metoo
« Reply #18 on: May 14, 2009, 03:30:00 PM »
Ok i have a 01 grand vitara and a 03 vitara the the GV has 16 in rims away bigger calipers,reg vitara has 15 in rims smaller calipers  u can put 16"s on reg vitara and rims off set is about 2inchs further out, on reg vitara i put 5on 5.5 ford after market rims 8 in wide also CJ's have same bolt pattern and same hub diameter. the only way u'll fit 31' without doin suspension lift and cutin the body, is 2in body lift and coil spacer but you'll have a stiffer ride a not much travel
