Sidekick wont start - injector related - Help!
  • 18 Replies
  • 6886 Views
Offline Bryce132
  • 117
Re: Sidekick wont start - injector related - Help!
« Reply #15 on: May 26, 2009, 01:13:20 PM »
Yeah that link was exactly what i was looking for in the first place.
I can NOT find my ECU ANYWHERE.
It does not seem to exist, i see many differnt numbers on ebay and rebuilt ones etc. but 33920-56B90 seems to be a RARE number, and I cant find one that will work? I tryed a 33920-56B30 from a 93 8V 5spd 2dr but no luck....
Bryce
« Reply #16 on: May 26, 2009, 02:17:06 PM »
I think that the 56B90 is a Canadian market ECU. I would expect a US version to work, have you got a pic of the inside of the ECU? It may be that you just need to move one of the config resistors to get the correct set up.
Offline Bryce132
  • 117
« Reply #17 on: May 26, 2009, 03:34:08 PM »
Mine is on the left. It looks exactly the same as the second picture taken from http://www.kick-fix.com/ECU/ECU.html
The gutts looked exactly the same as the B30 that I tried, except it was a different CPU in it. Everything else was identical.
Looks just like mine...
Bryce
« Reply #18 on: May 27, 2009, 06:00:25 AM »
If you have all the same components fitted/missing then the important factors are the numbers on the CPU which give the firmware revision and the four configuration resistors which are above the CPU. If neither ECU work then chances are that the problem is elsewhere.
