ARB Bulbar
  • 18 Replies
  • 6360 Views
Re: ARB Bulbar
« Reply #15 on: July 26, 2004, 11:32:34 PM »
I have installed both bumpers, the Calmini and the ARB Bullbar. Both were on 95 4 doors. Both were winch bumpers. From what I've seen between the two, the ARB mounts far superior to the Calmini. The ARB mounts to a heavy mounting crossmember that uses only the two upperbolts from the stock bumper mounts, uses 4 other bolts to hold the crossmember on the fron tof the frame, and they are all 1/2" bolts. 2 go in from the front down through the lower crossmemberfrom the inside using very heavy washers, nuts on the outside. The other 2 bolts go through the upper ends of the frame rails, THROUGH. They are drilled through frame rails and the crossmember has holes on both sides of the frame so the bolt goes all the way through 4 layers of steel on 2 frame rails!
Then there's the Calmini bumper. It is a very heavy bumper, that is honestly heavier than the ARB, but I think that part is debatable. But the mounting? SUCKS! It only mounts using the 4-8mm bolts that hold the factory beer can on. How is that strong enough for a side pull from a winch?
Calmini, what were you thinking? You made a beautiful, somewhat affordable, stout front bumper made in the states, that mounts like a$$! What's up with that? Why no extra mounting to help with the strength? Not like it would be a big deal to factor into the design.
That's my input, and gripe. Hope that helps.
2- factory bolts and 4- 1/2" :o. Jesus, seems like over kill to me for draging a 3000# truck around. You could pick up a tank with a mount like that :o
Did you have trouble with the Calmini mount? Or just not like how they did it? I watched a guy winching with one that was installed with no welding or additional mounting and it did not move at all. It was pulling a built Sami out of some deep thick mud at about a 45 degree angle. Seemed stout to me :-/
Offline vitaradownunder
  • 62
  • Vitara Doin' it Aussie Style
    • WildZooks
Re: ARB Bulbar
« Reply #16 on: July 27, 2004, 11:13:05 AM »
we have a ARB winch bar on our 4door Vit. It is awesome. I prefer the ARB bars follow the body line around the head lights and give protection against large shrubs.
Whoever i do really like the look of the Calmini Bar. It in my opinion is very stylish. However does not protect the head lights... and the are not fun to replace...
Pic of our Vit.
http://suzi-q.wildzooks.com/
Lets get wild and show the big  toys how to do it suzuki style.
Offline 97TRAKIN
  • 600
  • Suzuki in Chevy clothing.
Re: ARB Bulbar
« Reply #17 on: July 27, 2004, 03:03:08 PM »
Those pix are  :o, I like that!
Re: ARB Bulbar
« Reply #18 on: July 27, 2004, 03:57:47 PM »
Pic of our Vit.
Some people just build new brush gaurds to protect the lights. Its on my to-do list ;D
nice pics. Water looks cold ;D
