Scariest, most puckering moment...
  • 32 Replies
  • 9778 Views
Offline skahre
  • 22
Re: Scariest, most puckering moment...
« Reply #15 on: October 14, 2010, 11:11:52 AM »
Hmmm.  Unfortunately, I've only been driving my Tracker for a couple of years, and I don't do nearly as much "fun" stuff these days as I did years ago.
However, I do have a few good ones from my earlier days.  They all happened in my first rig, a '93 Chevy S-10 Ext. Cab 4X4.  It was all stock, as I never had enough money to mod. it.
The first one was heading out for a little wheeling in one of our local stomping grounds.  It was springtime, and it had been raining A LOT (at least for the high desert).  Me, and two of my buddies were all in my truck (sitting three across the front, since it never had any back jump seats).  We had to cross what was usually a dry, sandy wash a few hundred yards off the pavement in order to get into the hills.  When we got there, we were astonished to see that it was rushing with muddy water across its entire 20-yard width.  The smart thing to do would have been to get out and try to figure out how deep it was and if the bottom was smooth.  However, 17-year-olds are not famous for their smarts, and I was no exception.
I stuck it in 4-HI (figuring speed was better than torque), and gunned it.  The truck shot down the bank, and abruptly SLAMMED into a deep channel that the water had cut into the sand, bouncing the front end back up, and stopping nearly all forward momentum.  Neither of my buddies were wearing seatbelts, and both of their heads bashed the ceiling, leaving them yelling obscenities.  Once out of the hole, the foot-deep rushing water immediately started sluicing the sand out from under my tires, causing a sort of quicksand "sucking" effect.  I knew I couldn't stop to go into 4-LO, so I floored it and it was all the 4.3 V6 could do in 4-HI to keep the wheels turning in the sand.  We slowly chugged our way across and started up the muddy bank on the far side.  Then it was too slick, and it wouldn't go any more.  Half in and half out of the water, I managed to get into 4-LO and rocked it a few times and finally made it back up on flat ground.  After that ordeal, we ended up driving something like ten miles through the hills to get back to pavement WITHOUT crossing that creek again.
A year later, one of those same buddies tried to take his '71 Ford 2WD across that same spot when it was only MOIST (no flowing water), and sunk it to the axle.  It took his dad's 3/4 ton and lots of handyman jacking to get him out.
Another few years later, I was headed back up to college in the rain, and tried to pass a semi on a 2-lane highway.  When I was about halfway around, a full-size Chevy appeared in the oncoming lane.  I didn't have time to finish the pass, nor did I think I could slow down enough to get back behind the semi.  There were no shoulders, so I slammed on the brakes to take off a little speed and then veered left off the embankment.  It was really muddy, so my front tires locked up and basically pushed mud down the hill sideways, bouncing off of rocks at 55+ mph.  After careening diagonally down the embankment for at least fifty yards, I finally came to a stop on the steep sidehill, inches from the barbed wire fence separating the highway from the rangeland below.  Everything I had in the cab had gone flying across to my side and down at my feet.  With my heart still pounding, I got all of the stuff out from under my feet, put it in 4-LO, and scrawled it back up the embankment to the pavement.  Amazingly, nothing was damaged, but I didn't try to pass anyone else on that drive.  I'm convinced that a lower-clearance vehicle would have been severely damaged, and without 4WD, I wouldn't have been able to drive back up to the highway.
Okay, this is a really long post, so I'll save other stories for another day . . .
'02 Tracker 4dr 4X4
2.0L, 5-Speed
Stock except:
215-75R15 AT tires
Drilled-out airbox w/ K&N
« Reply #16 on: October 14, 2010, 03:56:28 PM »
Both those stories made my hair stand up on my arms! Glad your still with us buddy.
Offline TopHeavy96
  • 488
« Reply #17 on: October 14, 2010, 07:57:16 PM »
Nice story, kinda makes me miss my '89 2.8L 4x,  good times in that beater
Offline Tryggvi
  • 35
« Reply #18 on: October 18, 2010, 02:29:30 PM »
Regards from Iceland
Suzuki Sidekick Sport 1997 AT 33" - 1.8L - 3.5"+ 2" Lift
Rear axle skid plate - 5.83 R&P Locked Front & Rear
« Reply #19 on: October 18, 2010, 03:54:07 PM »
Now that was one hairy trip Tryggvi! We need Pictures!!!!
Offline Tryggvi
  • 35
« Reply #20 on: October 26, 2010, 11:18:36 AM »
Hi guys
I am sorry I do not have any digital pictures of the moment in question, no pictures of that moment at all actually. But I do have pictures on film of the trip. I found some pictures of the western Fjords of Iceland though that I hope will do, so people can get some idea of what I went through   :-\  I do hope these pictures are not copyright, They are not mine.
Best regards,
Tryggvi
« Reply #21 on: October 26, 2010, 11:59:23 AM »
That is beautiful counrty out there. No wonder you like to go...
« Reply #22 on: November 06, 2010, 02:33:39 PM »
This is from one of the trails over in Rimrock.  The pictures never do the hill justice, as usual.  But you get a nice off camber crawl down a steep hill on loose rocks while hugging the rocks with nothing but a nice roll down the hill if you slide off.  Most of the time you have a guy hanging on the inside of the rig to make sure you have enough weight on the inside corner.
And this is the only way out on the trail.  You either do this or turn around and drive all the way back out.  All the interesting moments I had in Moab were self inflicted, so they don't count on the same level as a path you have to take.
« Last Edit: November 06, 2010, 10:01:47 PM by Drone637 »
« Reply #23 on: November 06, 2010, 03:41:13 PM »
Not the worst but it was up there.
Offline sswilly
  • 10
« Reply #24 on: December 13, 2010, 01:36:15 AM »
 Well not quite up there with Tryggvi's ride the one moment that always comes to mind when asked about nerve wracking spills is the time in the early 90's when a bad snow storm hit southern B.C.  I was heading home in an old stepside GM 4x4 sporting a worn out set of desert dualers trying to find a route up the mountain side the whole town of Mission is built on. Figured I had it worked out and was almost to the top of a small section of a hill with a retaining wall on one side starting at about 3ft. and running up to 18"high at the top when I lost traction. Ok no problem just stop and back down right...ya right... the moment I took my foot off the gass I started sliding back down the hill. Brakes made no difference and the deep snow pulled the truck toward the drop off no matter which way I turned the wheel. My only thought was OGOD this is going to be bad...I just braced and over I went....as luck would have it the drop was only about eight feet at the section I went over. Leaving my truck sitting on the rear bumper with the back tires in the air and the fornt end hung up on the retaining wall just behind the front axle. I opened my door only to find I had a 5" jump to the ground on rubbery legs in the snow, must have looked like a cripple jumping out of the truck.
 It took about 45min. with a jack-all and the winch on my fathers 3/4ton to pull the old GM off the wall. The old truck was done for, bent frame, front suspention was buggered, and front tires had been driven up into the fender wells.
 The lesson I learned... don't drive GM's (kidding), tires are one of the most important safety items on your vehicle.
« Reply #25 on: December 16, 2010, 05:21:04 AM »
ARE WE ALL JUST ADRENELINE JUNKIES?
« Reply #26 on: December 31, 2010, 12:54:11 AM »
nothing happend, it just went faster down toward the road I panicked
YIKES!!  NO brakes huh?  Man that's like the worst feeling in the world!!  Glad you didn't crash!
How needs brakes in the open field. Just keep tires on the ground and enjoy the ride.
Offline Jordan
  • 161
  • Chrome don't get ya home, but it sure looks nice!
« Reply #27 on: January 01, 2011, 08:06:11 PM »
nothing happend, it just went faster down toward the ROAD I panicked[/quote]
[/quote]
[/quote]
In a field no, but on the road yes.
82 SJ410: 5" lift (spoa), home made cross over steering, bestop, custom rust lots of it,33"tsl, 6.5:1's. To install: Toyota diffs being built. To build: roll cage, traction bar, bumpers.
89 sidekick: lift 2"suspension 3"body, 31's, aluminum rims, warn hubs, (4) lights on roof, turbocharger.
« Reply #28 on: January 03, 2011, 06:02:18 AM »
Yep!!!!
Offline poopman
  • 86
« Last Edit: January 03, 2011, 12:21:54 PM by poopman »
