**SOLD** Parting out 2 samurais // NEED A PART? Let me know!!
  • 70 Replies
  • 14943 Views
0 Members and 37 Guests are viewing this topic.
Offline samuride1
  • 42
Re: Parting out 2 samurais // NEED A PART? Let me know!!
« Reply #30 on: December 21, 2010, 08:32:25 AM »
I need the passenger side wiper assembly.
Offline cimotorsports
  • 47
    • CI Motorsports
« Reply #31 on: December 29, 2010, 10:55:20 PM »
samuride1 , did you need the actual wiper arm the holds the wiper blade or the parts inside the windshiwld frame>?  LMK
1988.5 JX, 1.6 8v swap, Dual 40mm Dellorto carbs, DIY SPOA, 34x10.5x15 TSLs, Pacesetter Header, Custom Olive Green Spray Paint, 3 Piece Top, Misc Diamond Plate.  Check out  www:cimotorsports:net  for used Samurai parts!!
Offline tuxblacray
  • 20
    • Tuxblacray Photos
« Reply #32 on: December 30, 2010, 06:29:49 AM »
Would you take $15.00 for a gas tank filler hose protector shipped to 47240? Should be in the interior lower rear passenger side floor corner.
  • 47
    • CI Motorsports
« Reply #33 on: January 02, 2011, 12:03:45 PM »
Let me check and see if I still have a filler cover, ill let you know asap
Offline tuxblacray
  • 20
    • Tuxblacray Photos
« Reply #34 on: January 02, 2011, 12:32:56 PM »
Thanks, I appreciate that. I located 1 on Ebay but am looking for the best deal. If you can let me know by early Monday that would work.
        Tux...
« Last Edit: January 02, 2011, 04:46:41 PM by tuxblacray »
« Reply #35 on: January 03, 2011, 03:32:16 AM »
Are you done with both the Samurai. I was in search of the the pistons. I want 2 pieces. Reply I you still have in stock..
Offline tuxblacray
  • 20
    • Tuxblacray Photos
« Reply #36 on: January 04, 2011, 01:33:21 PM »
        Tux...
I went ahead and purchased the 1 one Ebay. I couldn't let it get away....
        Tux...
Offline tomcat
« Reply #37 on: January 05, 2011, 08:39:59 PM »
i need the heater switch...shiped to 97467
  • 47
    • CI Motorsports
« Reply #38 on: January 06, 2011, 07:44:31 PM »
Check your PMs guys!   Anyone else looking for anything??
  • 47
    • CI Motorsports
« Reply #39 on: January 07, 2011, 02:06:14 PM »
UPDATED LIST** Sorry for not posting this up the first time around guys!!
Windshield Glass  $35.00
Wiper motor  $15.00
Coolant Overflow Bottle  $10.00
Brake Booster w/reservior  $20.00
Multifunction switch (turn signal, wiper switch)  $40.00
Rear Driveshaft  (small flange) $50.00
Front Driveshaft (small flange)  $50.00
Intermediate Shaft  $20.00
OEM 1.3 Pistons and Rods  $40.00
Complete Door Hinge Set $40.00
Stock Rear 3rd Member ( real nice shape)  $65.00
Round vent dash Complete  $40.00
Heater core/ blower box  $25.00
Outer door handle set  $20.00
Drivers Inner door handle $7.00
Dash Support Bar Tube  $15.00
Doors  $35.00 each left or right  (come with glass, no handles)
Ignition switch, both door locks key  (all matching locks) $50.00
Gaige clusters  (non Tach)  20.00
Exhaust manifold $15.00
Intake Manifold  (no carb)  $20.00
Cylinder Head  (stripped bare, was going to rebuild)  $25.00
Rear Bumper  $20.00
Shift Boot $5.00
T case Boot  $5.00
Custom Turbo Manifold with Garrett T3,, comes with oil feed line, exhaust flange and BOV.  $300.00  (bought off a guy on zuwharrie and it sat on my shelf ever since)
Dellorto 40mm Sidedraft Carbs w/ Hawk intake manifold  and K&N filter setup $750.00   (Insane increase in power on my 1.6 8v!)
I offer very reasonable shipping rates thru Fedex.  I know I have other parts , if you dont see what you need on the list just ask. I may have it.
« Last Edit: January 18, 2011, 12:58:28 PM by cimotorsports »
Offline tazman
« Reply #40 on: January 11, 2011, 03:07:20 PM »
Do you have a steering gear box & hardware.
  • 47
    • CI Motorsports
« Reply #41 on: January 13, 2011, 12:43:28 PM »
Taz, check your PM
  • 47
    • CI Motorsports
« Reply #42 on: January 16, 2011, 11:06:58 PM »
Anyone else need anything?
Offline pup1286
« Reply #43 on: January 19, 2011, 07:19:53 AM »
Do you have any interior door pull handles left? I need 2.
  • 47
    • CI Motorsports
« Reply #44 on: January 19, 2011, 10:29:45 AM »
I have Pull handles, PM Sent.   Still got boxes and boxes full of parts.
Pedal Assemblies  $25.00
Complete Distributors , both for Carb and Fuel Injected Motors  $50.00 each
Cylinder Head Bare  $30.00
stock Pistons and Rods $25.00 Set
1.3 Crank  $30.00
Oil Pans  $20.00
Radiators  $25.00
Clutch Fans  $10.00
Motor Mounts
Exhaust Manifolds Both 1.3 and 1.6
Valve Covers
Timing Covers
Crank Pulleys
ETC ETC ETC
LET ME KNOW WHAT YOU GUYS NEED!
