ECU gone bad
  • 36 Replies
  • 7476 Views
Offline RuffTuff_95
Re: ECU gone bad
« Reply #15 on: January 13, 2004, 06:13:45 AM »
Ok, it's been almost a week now that I haven't had my zuk. :'(  I got a used ECU and gave it to the dealer today and expected it to be ready after lunch.  So, I called them, and now they're telling me that the new used one I brought in might be defective too?  What are the chances? ???  So now I'm really pissed off >:(  Why do I get the feeling that I'm being suckered.  What should I do?  If I decide to bring it to another place, I'll have to get it towed there since it's not in running condition.
Offline RuffTuff_95
Re: ECU gone bad
« Reply #16 on: January 13, 2004, 06:14:02 AM »
Offline RuffTuff_95
Re: ECU gone bad
« Reply #17 on: January 13, 2004, 10:32:09 PM »
UPDATE:  The new ECU I brought in apparently is defective too, so says the dealer.  The CEL codes that were brought up are P0202 & P0303.  The place I got the ECU from is sending me another one in exchange, and on thursday I'll know for sure if I'm being duped or it was just a freakish coincidence.
Offline NY_SIDEKICKER
  • 2274
  • YOU WANNA RACE THE ZUKE !
    • OBSESSIVE BEHAVIOR !
Re: ECU gone bad
« Reply #18 on: January 14, 2004, 12:01:30 PM »
GOOD LUCK...I'LL KEEP MY FINGERS CROSSED FOR YA.....
Offline RuffTuff_95
Re: ECU gone bad
« Reply #19 on: January 14, 2004, 12:40:25 PM »
UPDATE:  So after 3 ECU's it's still doing the same thing.  The tech has tested and traced all the wiring pertaining to the misfiring of injector #3 and he's stumped.  Damn electronic gremlins, DAMN YOU!  They're gonna consult suzuki techline services and see what else could be the problem.  Anybody have any ideas?
Offline Speedracer7c
  • 2210
Re: ECU gone bad
« Reply #20 on: January 14, 2004, 01:35:16 PM »
Hmm after 3 i'd think that the ECU isn't the problem...heheh
Offline jagular7
  • 1026
  • Jagular7
Re: ECU gone bad
« Reply #21 on: January 14, 2004, 03:42:12 PM »
I'm hoping they have swapped another injector to the 3 spot, being new or one from the other working spots on the engine. Then, they could disconnect the wiring to the injector and run a makeshift line to support the injector to make sure it's properly functioning.
Lenexa, KS
Re: ECU gone bad
« Reply #22 on: January 14, 2004, 04:28:39 PM »
How about a speck of dirt blocking the pintle open ??
Offline RuffTuff_95
Re: ECU gone bad
« Reply #23 on: January 14, 2004, 05:15:12 PM »
I believe the tech said that the injector is working fine it's just something is causing it to dump all the fuel into the cylinder.  Hence, the ECU.
Re: ECU gone bad
« Reply #24 on: January 14, 2004, 05:28:06 PM »
Ya but 3 in a row, Naw, something fishy is going on.
I would request they swap the injectors to confirm
computer or another problem, and I still think the
system is a one or two channel system, IE injectors
are fired in groups (batch), not individually.
Offline Z3bra
  • 273
Re: ECU gone bad
« Reply #25 on: January 14, 2004, 11:26:28 PM »
If it's dumping the fuel on the #3 only and a different injector does the same thing then I'd say it sounds like a short causing it to get power to the injector constantly.  That would stick it open.  Chasing down the where and why of the short might be fun though :(
Re: ECU gone bad
« Reply #26 on: January 15, 2004, 02:02:16 AM »
Injectors are supplied voltage all the time,
the pulse width is controlled by the ECU
grounding the circuit with a heavy duty
transistor, but one injector to be dumping
fuel, unless it is a multi channel IE 4 channel
system don't make sence.
Offline Samurai_Hamster
  • 28
    • Samurai Hamster
Re: ECU gone bad
« Reply #27 on: January 15, 2004, 10:49:47 AM »
THese ECU are made my Mitsubishi and are known to fail after a period of time.
There is a plce on the net that does rebuild them though.
Offline RuffTuff_95
Re: ECU gone bad
« Reply #28 on: January 15, 2004, 02:13:57 PM »
Yeah, I've seen them on the net.  But I've made my decision to take my truck outta there and bring it to another place.
Re: ECU gone bad
« Reply #29 on: January 15, 2004, 05:57:32 PM »
My 89' puter has been flawless for over 260,000
miles, and yes it's a Mitsu puter, it even tolerates
the turbo with narry a gripe, and you guys are having
all the fun !!  :(
