2.0 slug(gish)
  • 19 Replies
  • 5725 Views
Re: 2.0 slug(gish)
« Reply #15 on: March 28, 2011, 07:15:30 PM »
I put a converter test pipe in & that made no difference but I have moved the timing & it runs a little better  but ...I think the biggest thing I did was adjust the trans cable  its drivable now   but not like a friends rig w/ same engine? trans  combo
Do you have the 2 separate converters?  If yes, which one did you put the test pipe in?
Any insight on how you adjusted the trans cable?
I AM going to read over the FSM ffor how to adjust the linkage.
Offline Spitfire Rick
  • 123
  • fun lovin criminal
Re: 2.0 slug(gish)
« Reply #16 on: March 28, 2011, 10:34:26 PM »
I read something on how to do it in a chiltons book on line & really didnt quite understand it but mabee you could post what the fsm says about adjusting it
If I have to understand don't bother explaining
Offline narnwv
  • 16
Re: 2.0 slug(gish)
« Reply #17 on: March 30, 2011, 06:09:03 PM »
Well I put the hammer down on it today and got a CEL again.
0400 and 0402
Both point to EGR flow restrictions.  I'm going to try to tear into it when it's a bit warmer.
Re: 2.0 slug(gish)
« Reply #18 on: March 31, 2011, 08:01:00 AM »
TV cable adjustment.  loosen both nuts on tv bracket, hold accelerator pedal to floor, distance between tip end of cable and end of boot = .031 - .059".  pull cable until tight and tighten locknut, double check measurement
  • 123
Re: 2.0 slug(gish)
« Reply #19 on: March 31, 2011, 09:16:15 AM »
what I read about that adjustment neglected to mention the" hold the accelerator to the floor "part
