how much spacer is too much?
  • 21 Replies
  • 5266 Views
Offline 92Sidekick4x4
  • 1456
Re: how much spacer is too much?
« Reply #15 on: June 03, 2004, 10:12:39 AM »
What else do i need to do, i want to have a 2" coil spacer lift so do all i need is coil spacers, longer shox and strut spacers?
i have already started on the strut spacer, i am using chevy header flange, they costed 18 bucks for a steel one, since i need 4 i just baught the crappy kind of card board stuff and i traced it onto steel plate and i am making them that way, i think it will turn out good.
Offline 90Stomper
  • 427
« Reply #16 on: June 03, 2004, 10:21:01 AM »
you will prob need camber sdj bolts
http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&category=33581&item=2428584099&rd=1&ssPageName=WD1V
and maybe a driveshaft spacer.  then that should do it i think.  good luck!
2004 chevy tracker, 4door, V6
says 'Chevy' on the outside,
Offline extremekickin
  • 61
  • GO ZUKI OR GO HOME!!!
« Reply #17 on: June 04, 2004, 12:56:15 AM »
OK hold up! The flanges i also used for the spring spacers too. Pull the spring out and the rubber pad and put the 2" spacer in and put the pad and spring back in and dada you have lift! Ha i like it. And as fare as the camber bolt goes, Just take the top bolt out and put in a 7/16th bolt in it's spot. All works good for me.
P.S. make the spacer the same way as the strut one.
Hope this is a help. ;D ;D
« Last Edit: June 04, 2004, 12:58:42 AM by extremekickin »
1990 1.6L 8V kick,2.5" body and 2.5"sus lift,pro9000 ramsey winch. Full skids,30X9.5 mud kings,15X7steel wheels.Removable doors, Zuki Swift seats,Hi-lift,Steel rear bumper,Electric fan,K&N filter.
  • 1456
« Reply #18 on: June 04, 2004, 04:29:06 AM »
My plan  is to use 2" jeep spring spacers and then bore them out to what it has to be, and use the sturt spacers that i am making and then get a little longer shcok in the back, will this not work?
  • 61
« Reply #19 on: June 04, 2004, 05:56:57 AM »
it will work the front but the part that the spring sits in in the rear is not long enough to keep it in place on articulation.(top of spring) You have to make an extention for the back so the spring does not fall out.
Just make sure the shocks you get are not too long k. ;D
  • 1456
« Reply #20 on: June 04, 2004, 07:30:42 AM »
alright, sounds good! ;D thanks
Offline JDMCRX
  • 1110
  • 02 Grand Vitra Pimp lol
« Reply #21 on: June 07, 2004, 11:24:01 AM »
OK so u guys are using what the rocky-road coil spacers and a piece of 1/4 3 bolt header flange ontop of the front and rear coils for a tottal of 1.4" lift this works?
And strut spacers and longer shocks in the rear.??
01 GRAND VITARA
