Disappearing coolant / Losing coolant ???
  • 18 Replies
  • 8271 Views
Offline zacparry
  • 53
Re: Disappearing coolant / Losing coolant ???
« Reply #15 on: March 11, 2011, 08:57:36 AM »
yes the coolant will rise and bubble for a while but should go away. if the bubbles are constant I would do a leak down test.
[/quote]
Thanks for the info. How do I do a leak down test?
Offline Jluck
  • 1389
  • 40
« Reply #16 on: March 11, 2011, 09:01:56 AM »
you might be able to rent/borrow one maybe from your local parts house. ;)
Offline zacparry
  • 53
« Reply #17 on: March 23, 2011, 08:06:18 AM »
Just an Update.
I have not found the leak yet and have not had time to get the myside on so hopefully next weekend.  But, I have noticed some oil on the exhaust side of the block that looks like it is coming from the between the head and block, so I think I may just change the head gasket when I have it apart for the myside swap.
When I do figure out what it is I will post an update.
Thanks guys.
Offline zacparry
  • 53
« Reply #18 on: April 20, 2011, 07:12:09 AM »
Well, I got the head gasket changed and throughout the process I checked on the things you all mentioned and the coolant doesn't seem to be disappearing anymore and the temp guage says that the engine is running back at a normal temperature. ;D
I also put on a myside 2 and WOW!!  I never thought it would have been that easy to put on or tune.  And, it made my sammy even more fun to drive, something I did not think was possible. ;)  I still have a little bit of tinkering on the main jet but everything went well and the sammy is screaming now.
Thanks for all the suggestions for fixing my problem and a big thanks to Myron at ZOR for the great job on the myside!!  It is probably the best upgrade I could have ever done to my samurai.
