Mods to make Samurai zombie-proof
  • 24 Replies
  • 5375 Views
Offline ack
  • 1659
  • Professional askhole
    • Ack's FAQ
Re: Mods to make Samurai zombie-proof
« Reply #15 on: June 19, 2011, 06:44:32 PM »
On Ack's wish list, I would change out the 12 ga. slugs for double 00/9 ball or 6 ball.
                          Same range, but it has the same effect as a machine gun in body damage in 1 shot!!
                           30 cal. holes inbound, organ donor on the flip side!!
Point well taken!  the more damage to the brain, the greater chance of a terminating wound - or so the Zombie Killing Therory goes.  ;)
Ack
« Reply #16 on: June 20, 2011, 11:24:25 AM »
According to The Zombie Survival Guide a .22 is a better choice for long term survival.  It will damage the brain and the amount of ammunition you can carry is much greater.  Since only head shots count a bullet designed to damage as much flesh as possible can be a negative.  What good is a chest shot if the target doesn't breath?  It also gives you a false sense of security which can lead to wasting ammo and panicked shots in some situations.
The book is a fun read.  :)
Offline Capt
  • 738
  • 28
« Reply #17 on: June 20, 2011, 04:15:20 PM »
A GOOD POINT,
                          ..........But you are under the assumpsion that I am a good shot?!!!!
                                       I can't hit the Broad Side of a Barn..... FROM THE INSIDE !!!
                                           For me the "Scatter Gun" is a better choice.
CAPT
« Reply #18 on: June 20, 2011, 08:58:24 PM »
just remember rule #2 of zombieland: DOUBLE TAP!!  8)
Offline ack
  • 1659
    • Ack's FAQ
« Reply #19 on: June 21, 2011, 06:30:11 PM »
A GOOD POINT,
CAPT
Plus - I bet the FPS of big shotgun pellets at close range might do enough head-damage to get the job done.
However, I am the last person to believe when it comes to dispensing projectile weapon wisdom...   ;D
Ack
Offline Capt
  • 738
  • 28
« Reply #20 on: June 22, 2011, 06:55:18 AM »
I'd just would not want to be the TEST SUBJECT (Dummy /Mummy/ Zombie)
Offline krink545
  • 16
« Reply #21 on: June 24, 2011, 10:51:17 AM »
 Check out these to practice on , http://zombieindustries.com/
Offline Capt
  • 738
  • 28
« Reply #22 on: June 26, 2011, 06:10:27 AM »
I checked it out;     COOL !!
The life size 3-D ones are a little pricey.
I'll save this site if my "Gun Toting" buddies want to go in on these.
In the fall a "Cheap" COOL target for the same effect;
                       After Halloween, pumpkins go real cheap, get smaller ones about head size.
                             go to the "Dollar Store" and get Lime Jello,
                                 Cut a small 2" hole in the top, pour in the "Made Jello" (Note it take about 2 big jello mixes each)
                                    DO NOT FREEZE, but put in frige or if cool enough leave out over night.
Blast Away, the green jello and pumpkin guts,......... great effects!!!
CAPT
Offline Capt
  • 738
  • 28
« Reply #23 on: July 06, 2011, 05:42:03 PM »
Picked-up a copy of the "Zombie Survival Guide"
Interesting Book......After you buy into the "Solanum Virus" thing....
For Kicks, I keep this copy in the glove box so everyone will see it when you tell them to
"Pull the Hood Release Knob in the Glove Box".
CAPT
Offline Capt
  • 738
  • 28
« Reply #24 on: August 13, 2011, 04:14:18 PM »
MAYBE IT'S NOT ALL FAKE !!!!!!
Just read in the July/Aug 2011 Penn. State College (Alumni ?) magazine "PennStater" I found at the laundra-mat.
     On page 20; ZOMBIE ANTS ! Penn State entomologists have discovered a FUNGUS that turns ants into a ZOMBIE SPORE
BREEDER for up to a year.
          Here's the scary part....once in contact with the fungi, it infects the ants nervous system causing them to leave their
nest at a specific time of day, (solar Noon), seek out certain leaves at the right angle and height to face the sun, bite into the main leaf vein on the underside of the leaf, they become "Brain Dead" spore producing factories for up 1 year!!
Maybe them Jamaican Voo Doo witch doctors are on to something !!!
CAPT
