Which ECM for Sam 1.6L/8v Head and Block??
  • 16 Replies
  • 4698 Views
Re: Which ECM for Sam 1.6L/8v Head and Block??
« Reply #15 on: June 18, 2011, 09:03:17 PM »
The dual down pipe exhaust is a double walled unit to reduce
the radiated heat under the hood, you might want to use it
Offline mbruce
  • 139
« Reply #16 on: June 19, 2011, 11:57:30 AM »
It would be great if the bolts connecting the exhaust pipe to the manifold were on top rather than on bottom...
I'm thinking my options are buying a 2" extended for an impact so I can reach from underneath  or just cutting it off before cat converter since it will be replaced...I'm hoping I can use the dual down exhaust from the tracker so I won't have to buy a set...
Ignorant questions lead to a wealth of knowledge
