Guides or Seals??
  • 20 Replies
  • 9750 Views
Offline Sundance58301
  • 79
    • Dry Lake Farm
Re: Guides or Seals??
« Reply #15 on: September 19, 2011, 05:34:02 PM »
I installed DIY oil vapor catch cans onto the PCV and the VC breather line. They allow the oil vapors/fine mist to condense and turn back to a liquid state before entering the intake mani. Without the catch cans I noticed the interior of the intake mani on every 16v I have looked at was soaked in oil. This oil follows the course of gravity eventually ending up sitting on the backside of the valve and produce the same symptoms as a leaky valve stem seal.
23$ for the small air seperator filter and fittings
This is a great tip and makes sense. Can you post a picture of the
installed unit? I am a picture guy......
And where do you get this little gem?
Thanks
1992 Suzuki Sidekick JX
*4 Door
*5 Spd
*16V
« Reply #16 on: September 19, 2011, 05:57:32 PM »
It's an "off the shelf" oil/air separator/filter used with air tools - that one has two right angled fittings & hose barbs added.  Any decent industrial supply house should have something similar - print the picture and take it with you, show the guy behind the counter.  You may also find them at some Walmart & Sears locations.
This is the first time I'm seeing them used in this application - and I think it's a pretty neat idea.
Offline talonxracer
  • 1284
« Reply #17 on: September 19, 2011, 07:09:27 PM »
You can get everything at Walmart, Home Depot etc., I used the Campbell Hausfield version, and have used them on all my Honda's etc and now the Sidekick. I will take a pic tomorrow. you would be amazed at how much oil will be collected and how quickly it fills up!
« Reply #18 on: September 20, 2011, 06:45:05 AM »
Yes - you will have to drain off the oil as it collects.
  • 79
    • Dry Lake Farm
« Reply #19 on: September 20, 2011, 09:11:32 AM »
Excellent... The picture will help me figure out where and how to
hook it up.
Thanks
*4 Door
*5 Spd
*16V
  • 79
    • Dry Lake Farm
« Reply #20 on: September 21, 2011, 09:28:41 AM »
Talon....  you said "catch cans" plural. Did you install 2 of
these??
*4 Door
*5 Spd
*16V
