Fan / Water Pump Pulley Bolts
  • 17 Replies
  • 5261 Views
Offline jerryp58
  • 449
Re: Fan / Water Pump Pulley Bolts
« Reply #15 on: May 08, 2004, 03:55:22 PM »
Well, got the electric fan in today.  It's wired with a probe thermostat and a separate cut-off switch. The fan seems pretty powerful.  It's an eBay purchase off of a Daewoo car supposedly.  I think it'll work out fine.  Mounting was a little weird, but I think I have it secure.  I guess time will tell.
I pulled one of the water pump pulley studs and took it to the local Home Depot but wasn't able to find a matching bolt.  The size looked to be M6-1 (whatever that means).  HD doesn't seem to carry a lot of metric.  I think it's gonna take some searching to find replacements.  At least they're not in the way.
After I've lived with the fan for while, I guess I'll post my feelings about it.
Thanks to all for the help.
Jerry
Offline 90Stomper
  • 427
« Reply #16 on: May 08, 2004, 04:06:27 PM »
well i put about 8 miles on mine tonight breaking in the pistons seals, which is a lil stressfull, temp only got a lil over 1/3 on guage ;D, but the temp outside is under 70 and it was raining a bit but im hopeful.
nic pics, thanks.  mine is ALOT different.
 i can garantee you that HD, manards and lowes will not have what your looking for, i have looked.  need to goto a auto parts store or an industrial supply store, LOTS of bolts ;)
good luck and please keep posted on how this works out and i will do the same 8)
2004 chevy tracker, 4door, V6
says 'Chevy' on the outside,
« Reply #17 on: May 08, 2004, 07:17:00 PM »
My local Ace Harware has a real kickass
hardware selection, even Metrics, I just
used some short 10 or 15 mm bolts
m6-1 means 6mm 1 thread per mm
8-1.25 is 8mm 1.25 threads per mm
and so forth, more threads per mm
is a fine thread, less is a coarse thread
hope this helps
