Very Rough Idle on Sidekick 1992
  • 16 Replies
  • 10688 Views
Re: Very Rough Idle on Sidekick 1992
« Reply #15 on: January 10, 2012, 02:09:43 PM »
Thanks for the reply.
So I used a screw in type compression tester, and yes did have all of the plugs out.  But I did not have the throttle body plate wide open.  Would that make that big of a difference?
The check engine light does not come on while cranking, but I do not know how to check to see if it is burned out or not.
The exhaust does have a leak and as I said before there is not catalytic converter, just exhaust manifold to a glass pack.  Could this cause a problem.
I have called around to different shops in my area and they all want to charge well over $2000 to rebuild my engine.  Most of them want to charge over $700 just for the parts.  I have seen a rebuild parts kit on Ebay for $230.  Does anyone know if these are quality parts or not?  Here is the link
http://www.ebay.com/itm/Suzuki-Sidekick-Geo-Tracker-1-6L-8V-Overhaul-Engine-Kit-/300496978370?pt=Motors_Car_Truck_Parts_Accessories&fits=Model%3ASidekick&vxp=mtr&hash=item45f70401c2
My last question is, my zuki runs plenty good enough to get around town.  If I were to change out the motor mounts, would driving it in its current condition do further damage to the engine?  I am talking about just easy driving below 4o mph.
Thanks for any input you have.
Offline Sundance58301
  • 79
    • Dry Lake Farm
« Reply #16 on: January 10, 2012, 04:08:15 PM »
A $230 rebuild kit is suspect to me. The quality master/major kits
I've seen are mid $300's to $450.
1992 Suzuki Sidekick JX
*4 Door
*5 Spd
*16V
