Replacing front wheel bearing
  • 16 Replies
  • 8340 Views
0 Members and 14 Guests are viewing this topic.
Offline Digger
  • 1991
  • 1996 Suzuki X-90 4X4
Re: Replacing front wheel bearing
« Reply #15 on: February 29, 2012, 10:52:50 PM »
To be honest, I don't know exactly what vehicle it was for or what year. I just saw it on the tool rack in the store and thought to myself that it looked close enough that I bet I could make it work. It was less than $20. I had the lock ring in my pocket at the time and it lined up really closely so that it was clear all I had to do was round the posts to fit the holes...
Offline gravity_storm
  • 108
  • The wino and I know
« Reply #16 on: March 14, 2012, 06:38:44 PM »
Well, I finally got it back together last Saturday. I resurected my brother's old press (took a new 20 ton bottle jack). I heated the hub and froze the race and they went together without issue. I built my own socket to tighten the nut. It is without a doubt the sorriest piece of fab work I have ever done, in fact I hid it so that noone could see it but it worked.
My attempt at the 4 door brake conversion failed. The bracket that comes on the fully loaded 4 door caliper was too thick to clear the rotor. The 2 door bracket is probably between an eigth and three sixteenths thinner and fits just fine. I was terribly disapointed but at least I never disconnected the lines from the old calipers so no need to bleed the brakes. It saved me a chunk of change as well. Still very disapointed.
Once again, thanks to all for the advice, you guys rock.
gravity_storm
1996 Sidekick, 1.5" homegrown body lift, 2" Digger suspension lift, home made snorkle, front skid
