coil spacer specs
  • 48 Replies
  • 10808 Views
Offline 1bigtracker
  • 3409
Re: coil spacer specs
« Reply #45 on: April 02, 2004, 02:52:32 PM »
I did my XJ 2" coil spacers today.  A   2.5" = 64mm  hole saw worked perfect.  The XJ spacers look like they were made to fit once the center was open up with the hole saw.  Sorry been wrenchin all day no pics.
Chopped a Kick fram at the mirrors forward.  Now I have a jig to work my custom suspension off of.
wow i thought i was the only one that would do somthing like that you build stuff. i guess we have alot in common
stu
Offline TN_Tracker
  • 1113
    • TN Tracker's Suzuki Space
« Reply #46 on: April 03, 2004, 01:56:43 PM »
I got my spacers installed today and wanted to give those that are making their own spacers a tip. Add at least a millimeter or two to the 76mm dimension. The RRO Spacers fit tight. So you will need a little more tolerance for aluminum.
;D
Offline DirtDevil
  • 317
  • Island4x4.com
« Reply #47 on: April 03, 2004, 05:31:07 PM »
thanxs dude, hows the truck look ?? driven it yet?
Offline TN_Tracker
  • 1113
« Reply #48 on: April 04, 2004, 12:56:20 AM »
The truck looks and drives great. No problems at all. I bought a set of TRW Camber Bolts at Advance Auto and they seem to do the job. I used a pitch gauge from Sears to check the camber but will soon be getting an alignment.
NOTE: I rented a exterior spring compressor from Autozone and it helps a lot with the install.
« Last Edit: April 04, 2004, 01:43:42 AM by TN_Tracker »
